I will have to disagree..
IF a system never changes this is true.
Thats patently untrue in the case of HA. The system and underlying plumbing has SIGNIFICANTLY changed inthe last three years and in next version you’ll even need to change the proc type in Prox to even allow it to boot.
Yes two cores (is an A9 hyperthreaded I can’t remember… But 2 HT cores != 4 cores) can absolutely run HA especially w 16gb ram. It will absolutely also cause contention with OS base processing because proc queueing.
Now in an exploration sure knock yourself out. But understand it will creep along and clunk and sometimes exhaust threads and wierd stuff happens for no good reason…
BUT. With a newbie struggling with a new box and hoping they get a good experience? Asking if a machine is even VIABLE?
No!
Let’s not complicate the situation. In this -specific- case prox will probably make it worse.
And op - before I wasn’t saying don’t use this box I was saying dont attempt to Hyperv that box in windows. - primarily bec the USB pass through issue mostly but that box honestly doesn’t have enough chooch for hypervisor AND a passenger OS. Either or. Probably ok.
So please read everything above as options you CAN do a lot of stuff. Read up, it’s interesting as hell. But in HA you will find - like in windows land you CAN do it a bunch of different ways. (and many of them aren’t optimal) The ones that work for you may not work for someone else.
Now for the rest of us. Who are going to stop arguing on this nice ops thread… (right?)
When you give advice please stop and think if the advice is appropriate for the situation before just tossing It yes virtualization works, bare metal works this works that works but for this situation. With someone starting out on a less than optimal machine. Start SIMPLE. then if they have a good experience move on to more advanced config.
This machine is perfectly good for haos or container but I prob wouldn’t run container or haos INSIDE another virt platform because limited proc in this machine (personally I require four real not hyperthreaded cores before I even consider virt.)
Also op. I hope you get hooked on your new install and It makes you immediately want to go buy a new rig to run it on.
good luck.
