Newbie: adding a second automation, the first one becomes inactive
Hi, first week of HA and struggling with this. I want to add my LG webos tv manually. Webostv plattform added and working. I have an automation for a drop-down menu to change the source: it works. But when I add a second automation to change the channels, the first one doe snot work anymore. The second automation alone also works. What am I missing?
alias: "Trocar entrada da TV"
  - platform: state
    entity_id: input_select.tv_source
  - service: media_player.select_source
      entity_id: media_player.lg_webos_tv_oled55b9dla
      source: "{{ states('input_select.tv_source') }}"
mode: restart
alias: "Trocar canal da TV"
  - platform: state
    entity_id: input_select.tv_channel
  - service: media_player.play_media
      media_content_id: "{{ states('input_select.tv_channel') }}"
      media_content_type: "channel"
mode: restart
also tried with all possible automation modes.
Automations are a list not a dictionary. See: Thomas Lovén - YAML for Non-programmers
- alias: "Trocar entrada da TV"
    - platform: state
  mode: restart
- alias: "Trocar canal da TV"
    - platform: state
  mode: restart
Thank for the link @tom_l . I realized now thatwas not the second automation which makes my first not working, but the second input_select. With only the first input_select (sources) it works. With both (sources and channels) the first one does not work anymore. Could you take a look please?
automations:
    - platform: state
  mode: restart
    - platform: state
  mode: restart
configuration:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
input_select:
  tv_source:
    name: Fonte da TV
    options:
      - Apple TV
      - Disney+
      - Foto und Video
      - GALERIE
      - HDMI 1
      - HDMI 2
      - HDMI 3
      - Live TV
      - Moonlight
      - Netflix
      - Plex
      - Prime Video
input_select:
  tv_channel:
    name: Canal da TV
    options:
      - "1"
      - "2"
      - "3"
      - "4"
      - "5"
    initial: "1"
    icon: mdi:television
input_select: defines an integration/helper it should only appear once in your configuration.yaml file. If you have multiple input selects then they need to be defined as a dictionary under the single instance of input_select: e.g.
default_config:
frontend:
input_select:
  tv_source:
    name: Fonte da TV
    options:
      - Apple TV
      - Disney+
      - Foto und Video
      - GALERIE
      - HDMI 1
      - HDMI 2
      - HDMI 3
      - Live TV
      - Moonlight
      - Netflix
      - Plex
      - Prime Video
  tv_channel:
    name: Canal da TV
    options:
      - "1"
      - "2"
      - "3"
      - "4"
      - "5"
    initial: "1"
Or you could use an !include and put all your input selects in a separate file.
Perfect. Tks.
