Newbie - integrating MQTT sensors
I’ve just installed HASS on RPi 3 in order to manage some devices at home. I used the pre-built image, set up a static IP and can access HASS.
I also installed Mosquitto brocker add-on and tried to use it with an existing MQTT sensor I have. Here are the broker options:
> certfile: fullchain.pem
> customize:
>   active: false
>   folder: mosquitto
> keyfile: privkey.pem
> logins: []
> require_certificate: false
When I try using the broker from another pc with mosquitto_pub and mosquitto_sub, nothing happens. I can’t see a message going through, even though the mosquitto_pub command says it’s connecting OK.
After that I tried adding a sensor in configuration.yaml:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
    - platform: mqtt
      state_topic: "sdm120/voltage"
    - platform: mqtt
      state_topic: "sdm120/current"
    - platform: mqtt
      state_topic: "sdm120/totalenergy"
I can then add these sensors to the dashboard, but no matter what and how I publish something to the topics above, I don’t see any messages.
Is there some setting I need to allow on the Mosquitto add-on so that it will rely the messages? I’ve been wrestling with that for hours and don’t know what else to try. When I use another Mosquitto broker for my sensors, they work fine.
