Newbie needs Help - Notification when Netatmo Temperature Outside is lower than Inside
i am new to home assistant, so i apology in advance for my question:
How can i do it to get an notification if the Temperature from one Netatmo Sensor (outside) is lower than a Netatmo Sensor inside?
I tried it but i can only set a temperature threashold or i am too stupid.
any help is welcome!
In the UI, under Helpers, Template, create a Template Binary Sensor with a state template of:
{{ states('sensor.outside_sensor')|float(0) <
   states('sensor.inside_sensor')|float(0) }}
substituting in the correct entity IDs for your sensors (in future, please include them in your posts). Should look like this with your entity IDs:
Then create an automation (Create Automation. Create New Automation):
When / Add Trigger / Entity / State
Select your entity, set the To box to On, leave everything else blank
Then set up the notification you want. Should look like this but with your notification setup:
That will send a notification whenever the binary sensor turns on — that is, every time a new sensor reading makes the criterion true when it was previously false.
You might find as temperatures fluctuate that you get a few notifications in quick succession. See how it goes and we can work around any issues that arise.
Wow, i created everything, now i am excited if it works :slight_smile:
Thanks so much for helping me out!
I will report later how its going :slight_smile:
Thanks, everything works well!
