I finally got HA setup and activated HACS. I now have the Lucid Integration downloaded. How do I activate it so that it sees my car?
(feeling old and ludidteish
You did read the docs I guess? If so which bit are you stuck on?
Yes. I read it but didn’t understand most of it. I assumed that I would click on it and it would run.
I am lost from here
Configuration is done in the UI
I know what UI stands for but don’t know where it is in HA
try this.
Might be worth reading this as well.
This is helpful. Thanks
Bookmark this page, you will find it useful as you go on. The worst part is finding the right document, when you don’t even know what to call something. People will point you at the docs as its easier than rewriting them. Once you know where to find the answers it all becomes much easier.
https://jackjourneyman.github.io/homeassistantindex/index.html
