Newbie stuck on Home Assistant onboarding screen
@balloob - I deleted my VM and recreated it from scratch using the 2023.5.2 and wanted to let you know that it did indeed fix the issue. Thanks for finding the issue and implementing a fix so fast! Very impressed! That’s what makes HA so great!
When will this be fixed in Hassio? Just downloaded and stuck on this :frowning: Thanks
I did ha core update at the console and the issue is resolved. Thanks
Thanks a lot. You saved me a lot of time…
Issue is still here.
Installed HA using the PI Imager on a Pi4.
After I log in, this is the only thing I see:
After the login it is supposed the show a map if I remember correctly.
Tried 5 different browsers, private windows etc etc.
Doing inspect on the page shows several errors:
