Newbie to Automation
I am new to automations but I am trying to do something basic.
I would like one of my sonoff relay to turn on if someone is home and it is 45 mins before sunset. I would also like the relay to turn off if there is no one home or it is after 10:30pm. Below is what I have so far but for some reason it is not triggering properly.
- id: no_one_home
  alias: No one home
  - entity_id: device_tracker.iphone1
platform: state
state: not_home
  - entity_id: device_tracker.iphone2
platform: state
state: not_home
  - data:
entity_id: switch.extension_cord
service: light.turn_off
- id: lights_on_at_sunset
  alias: Lights on at sunset
  - event: sunset
offset: -00:45:00
platform: sun
  - entity_id: device_tracker.laurensiphone
platform: state
state: home
  - entity_id: device_tracker.codysiphone
platform: state
state: home
  - data:
service: light.turn_on
- id: turn_lights_off_at_night
  alias: Turn lights off at night
  - hours: 22
minutes: 30
platform: time
  - data:
Any assistance would be amazing!
Welcome!!! I think this will do what you need… Feel free to ask questions below!
Edit: If these work I challenge you to add conditions to the first and last automations so that they only trigger if the Sonoff is already on!
- id: no_one_home
  alias: No one home
  - platform: state
     to: not_home
  - platform: state
     to: not_home
  - service: light.turn_off
    platform: sun
    event: sunset
    offset: -00:45:00
  condition:
    condition: or
    conditions:
      - condition: state
        state: home
      - condition: state
        state: home
    - service: light.turn_on
    platform: time
    after: 22:29:59
Thank you so much!
For the conditions that you mentioned. Would it be something like this for all three automations:
    platform: time
    after: 22:29:59
condition:
     - condition: state
        state: 'off'
Very close. You’ll want the condition to check that the switch is on. Also, make sure the condition line is the same indent level as trigger and action. Nicely done!
    platform: time
    after: 22:29:59
  condition:
    condition: state
    state: 'on'
Thank you again for looking at this. I think this should be correct now.
I am still having issues and I am not sure what is causing it. This is the error code that I am receiving. I sarched the forums but everything I tried failed. This is the error.
2017-05-24 22:25:05 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: Invalid time specified: 80999 for dictionary value @ data['trigger'][0]['after']. Got None. (See /home/pi/.homeassistant/configuration.yaml, line 108). Please check the docs at https://home-assistant.io/components/automation/
This is my configuration:
- id: no_one_home
    - entity_id: switch.extension_cord
  alias: "No one home"
    - entity_id: device_tracker.siphone1
      platform: state
      to: not_home
      platform: state
      to: not_home
  alias: "Lights on at sunset"
  condition:
    condition: or
    conditions:
      - condition: state
        state: home
      - condition: state
        state: home
    event: sunset
    offset: -00:45:00
    platform: sun
  alias: "Turn lights off at night"
    after: 22:29:59
    platform: time
This is line 108 from configuration.yaml as the error says.
#Automations
config:
Strangely the No one home automation seems to be valid though I have not been able to test that it works successfully yet.
You have everything backwards. It should go:
triggers:
conditions:
actions:
