Newbie : Zigbee2MQTT failure to install / frontend
Hey all,
I really am quite a newbie with this stuff. I’m trying to learn / follow guides / get lost with chatGPT help - but I’ve really hit a roadblock.
I’ve got a 2018 mac mini I’ve installed ubuntu 24.04 server onto, and got home assistant up and running using docker compose. Then installed Mosquitto just fine (I think) and for fun got portainer up and running but haven’t really used it yet.
The fun and games came when trying to get Zigbee2MQTT up and running.
I’ve got a SLZB-06 up and running. I can connect to it - although it is not allowing me to update it to use a static IP address. For the moment, thats cool. I can cope with it being on DHCP.
Now to bring it all together.
I have both my zigbee2mqtt config yaml and docker compose yaml setup as best I can. I’ll paste it all below.
Some things appear working, others do not. I cannot get to the frontend (tried a variety of machines), yet can’t see specific things in the logs which indicate why.
I have changed port from 8080 to 8081 after I couldn’t connect to the server via
“curl http://localhost:8080
Nor
“curl http://192.168.1.90:8080
(where .90 is my ubuntu box I’m configuring)
So something is seriously odd. Home assistant and portainer front ends both work fine.
The current config files are as follows.
Zigbee2MQTT:
homeassistant:
  enabled: true
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://127.0.0.1:1883
  user: hass
  password: [hidden]
serial:
  port: tcp://192.168.1.135:6638
  adapter: zstack
advanced:
  log_level: debug
version: 4
frontend:
  enable: true
  port: 8081
  host: 0.0.0.0
And to my docker yaml
services:
  portainer:
    container_name: portainer
    image: portainer/portainer-ce
    restart: always
    ports:
      - "9000:9000/tcp"
    environment:
      - TZ=Australia/Sydney
    volumes:
      - /var/run/docker.sock:/var/run/docker.sock
      - /home/klangadmin/dockertest/portainer:/data
  homeassistant:
    container_name: homeassistant
    image: "ghcr.io/home-assistant/home-assistant:stable"
    volumes:
      - /home/klangadmin/dockertest/homeassistant/config:/config
      - /etc/localtime:/etc/localtime:ro
    restart: unless-stopped
    privileged: true
    network_mode: host
  mosquitto:
    image: eclipse-mosquitto
    container_name: mosquitto
    volumes:
      - /home/klangadmin/dockertest/mosquitto:/mosquitto
      - /home/klangadmin/dockertest/mosquitto/data:/mosquitto/data
      - /home/klangadmin/dockertest/mosquitto/log:/mosquitto/log
    ports:
      - 1883:1883
      - 9001:9001
  zigbee2mqtt:
    network_mode: host
    container_name: zigbee2mqtt
    image: koenkk/zigbee2mqtt
    privileged: true
    volumes:
      - /home/klangadmin/dockertest/zigbee2mqtt/data:/app/data
      - /run/udev:/run/udev:ro
    ports:
      - 8081:8081
    environment:
I really don’t know which way to turn right now.
I’ve tried running in host mode (as its setup now) - but with no difference.
I’m not really sure what do try / where to go next. I’m at the edge of my abilities with all this, but I do know theres a bunch I don’t know that I could have easily overlooked. I just don’t know where to even look right now.
Any help would be most appreciated.
If all of your questions are not answered here, then this might be another place to ask,
I’ll defninitely do this.
I’ve spent another few hours going in circles.
I’m currently going round installing everything from scratch (clean ubuntu!) - learning a bit about snaps vs apt along the way (which explains some other issues I was having earlier as well…)
Thanks for the info about the discord server.
