Hello everyone,
I’m experiencing an issue while installing Home Assistant on my Raspberry Pi 4. The following error message appears in the logs:
[supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
My internet connection is working fine, and I can access GitHub from my browser. I’ve already tried changing the SD card and even replacing the Raspberry Pi, but the problem persists.
Does anyone have any ideas or solutions to help me get Home Assistant working properly?
Thanks in advance for your help!
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[17:25:31] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[17:25:31] INFO: Starting local supervisor watchdog...
2025-11-05 17:25:37.528 INFO (MainThread) [__main__] Initializing Supervisor setup
2025-11-05 17:25:37.599 INFO (SyncWorker_0) [supervisor.docker.network] Can't find Supervisor network, creating a new network
2025-11-05 17:25:38.150 ERROR (SyncWorker_0) [supervisor.docker.network] Can't find hassio_observer: 404 Client Error for http+docker://localhost/v1.51/containers/hassio_observer/json: Not Found ("No such container: hassio_observer")
2025-11-05 17:25:38.156 ERROR (SyncWorker_0) [supervisor.docker.network] Can't find hassio_cli: 404 Client Error for http+docker://localhost/v1.51/containers/hassio_cli/json: Not Found ("No such container: hassio_cli")
2025-11-05 17:25:38.162 ERROR (SyncWorker_0) [supervisor.docker.network] Can't find hassio_dns: 404 Client Error for http+docker://localhost/v1.51/containers/hassio_dns/json: Not Found ("No such container: hassio_dns")
2025-11-05 17:25:38.168 ERROR (SyncWorker_0) [supervisor.docker.network] Can't find hassio_audio: 404 Client Error for http+docker://localhost/v1.51/containers/hassio_audio/json: Not Found ("No such container: hassio_audio")
2025-11-05 17:25:38.300 INFO (MainThread) [supervisor.coresys] Setting up coresys for machine: raspberrypi4-64
2025-11-05 17:25:38.315 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2025.11.1
2025-11-05 17:25:38.316 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2025-11-05 17:25:38.940 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2025-11-05 17:25:38.946 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-11-05 17:25:38.947 INFO (MainThread) [__main__] Setting up Supervisor
2025-11-05 17:25:49.855 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2025-11-05 17:25:50.141 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2025-11-05 17:25:50.151 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2025-11-05 17:25:50.154 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2025-11-05 17:25:50.158 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2025-11-05 17:25:50.160 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2025-11-05 17:25:50.162 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2025-11-05 17:25:50.163 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2025-11-05 17:25:50.164 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2025-11-05 17:25:50.165 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2025-11-05 17:25:50.166 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2025-11-05 17:25:51.083 INFO (MainThread) [supervisor.host.services] Updating service information
2025-11-05 17:25:51.104 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-11-05 17:25:51.119 WARNING (SyncWorker_2) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
2025-11-05 17:25:51.658 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-11-05 17:25:51.899 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2025-11-05 17:25:52.075 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 16.3 / BootSlot A
2025-11-05 17:26:02.738 WARNING (MainThread) [supervisor.utils.whoami] Can't fetch Whoami data: Timeout
2025-11-05 17:26:02.738 WARNING (MainThread) [supervisor.core] Can't adjust Time/Date settings: Can't fetch Whoami data: Timeout
2025-11-05 17:26:02.756 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2025-11-05 17:26:02.756 INFO (MainThread) [supervisor.updater] No OS update information found, force refreshing updater information
2025-11-05 17:26:02.756 INFO (MainThread) [supervisor.updater] No Supervisor connectivity, delaying version fetch
2025-11-05 17:26:02.804 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2025.09.0'>]
2025-11-05 17:26:02.826 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2025.09.0
2025-11-05 17:26:02.881 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
2025-11-05 17:26:04.209 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2025.09.0 - 172.30.32.5
2025-11-05 17:26:04.302 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2025.08.0'>]
2025-11-05 17:26:04.337 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2025.08.0
2025-11-05 17:26:04.405 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
2025-11-05 17:26:05.997 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2025.08.0 - 172.30.32.3
2025-11-05 17:26:06.002 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2025-11-05 17:26:06.075 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2025.08.0'>]
2025-11-05 17:26:06.103 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2025.08.0
2025-11-05 17:26:06.147 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
2025-11-05 17:26:07.544 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2025.08.0 - 172.30.32.4
2025-11-05 17:26:07.594 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2025.02.0'>]
2025-11-05 17:26:07.611 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2025.02.0
2025-11-05 17:26:07.708 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
2025-11-05 17:26:09.413 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2025.02.0 - 172.30.32.6
2025-11-05 17:26:09.452 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2025.08.0'>]
2025-11-05 17:26:09.477 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2025.08.0
2025-11-05 17:26:09.519 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
2025-11-05 17:26:10.535 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2025.08.0 - Host
2025-11-05 17:26:10.540 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
2025-11-05 17:26:10.581 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi4-64-homeassistant
2025-11-05 17:26:10.581 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant found.
2025-11-05 17:26:10.609 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
2025-11-05 17:26:10.610 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
2025-11-05 17:26:10.639 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
2025-11-05 17:26:10.686 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2025-11-05 17:26:11.830 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
2025-11-05 17:26:11.848 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
2025-11-05 17:26:11.849 ERROR (MainThread) [supervisor.store] Can't add repository core due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
2025-11-05 17:26:11.849 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / core
2025-11-05 17:26:11.849 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
2025-11-05 17:26:11.851 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
2025-11-05 17:26:11.852 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/esphome/home-assistant-addon due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
2025-11-05 17:26:11.852 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / 5c53de3b
2025-11-05 17:26:11.853 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
2025-11-05 17:26:11.854 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
2025-11-05 17:26:11.854 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/hassio-addons/repository due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
2025-11-05 17:26:11.855 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / a0d7b954
2025-11-05 17:26:11.855 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
2025-11-05 17:26:11.860 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
2025-11-05 17:26:11.860 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/music-assistant/home-assistant-addon due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
2025-11-05 17:26:11.861 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / d5369777
2025-11-05 17:26:11.861 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / d5369777
2025-11-05 17:26:11.886 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
2025-11-05 17:26:11.886 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
2025-11-05 17:26:11.893 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
2025-11-05 17:26:11.893 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
2025-11-05 17:26:11.893 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2025-11-05 17:26:11.893 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2025-11-05 17:26:11.894 INFO (MainThread) [supervisor.resolution.checks.base] Run check for deprecated_addon/addon
2025-11-05 17:26:11.894 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-11-05 17:26:11.895 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2025-11-05 17:26:11.895 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2025-11-05 17:26:11.895 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-11-05 17:26:11.895 INFO (MainThread) [supervisor.resolution.checks.base] Run check for duplicate_os_installation/system
2025-11-05 17:26:12.995 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-11-05 17:26:12.996 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2025-11-05 17:26:12.996 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-11-05 17:26:12.998 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2025-11-05 17:26:12.063 INFO (MainThread) [supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as good
2025-11-05 17:26:12.101 INFO (MainThread) [supervisor.updater] No Supervisor connectivity, delaying version fetch
2025-11-05 17:26:12.101 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2025-11-05 17:26:12.122 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
2025-11-05 17:26:12.122 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
2025-11-05 17:26:12.130 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
2025-11-05 17:26:12.131 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
2025-11-05 17:26:12.146 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2025-11-05 17:26:12.147 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
2025-11-05 17:26:12.147 INFO (MainThread) [supervisor.updater] No Supervisor connectivity, delaying version fetch
2025-11-05 17:26:12.147 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
2025-11-05 17:26:12.148 INFO (MainThread) [supervisor.host.info] Updating local host information
2025-11-05 17:26:12.152 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-11-05 17:26:12.152 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-11-05 17:26:12.153 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connection
2025-11-05 17:26:12.153 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-11-05 17:26:12.154 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-11-05 17:26:12.154 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2025-11-05 17:26:12.155 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2025-11-05 17:26:12.155 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2025-11-05 17:26:12.155 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-11-05 17:26:12.158 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connection
2025-11-05 17:26:12.158 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-11-05 17:26:12.159 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-11-05 17:26:12.159 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-11-05 17:26:12.170 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-11-05 17:26:12.171 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-11-05 17:26:12.171 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
2025-11-05 17:26:12.172 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disk_lifetime/system
2025-11-05 17:26:12.175 INFO (MainThread) [supervisor.core] Supervisor is up and running
2025-11-05 17:26:12.177 INFO (MainThread) [__main__] Running Supervisor
2025-11-05 17:26:12.180 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-11-05 17:26:12.180 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-11-05 17:26:12.234 INFO (MainThread) [supervisor.host.services] Updating service information
2025-11-05 17:26:12.249 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-11-05 17:26:12.265 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-11-05 17:26:12.266 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-11-05 17:26:12.275 WARNING (MainThread) [supervisor.jobs] 'FixupStoreExecuteReload.process_fixup' blocked from execution, no supervisor internet connection
2025-11-05 17:26:12.275 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2025-11-05 17:26:12.599 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-11-05 17:26:12.627 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2025-11-05 17:26:42.151 INFO (MainThread) [supervisor.updater] No Supervisor connectivity, delaying version fetch
2025-11-05 17:26:42.152 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
2025-11-05 17:27:12.156 INFO (MainThread) [supervisor.updater] No Supervisor connectivity, delaying version fetch
2025-11-05 17:27:12.156 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
2025-11-05 17:27:42.159 INFO (MainThread) [supervisor.updater] No Supervisor connectivity, delaying version fetch
2025-11-05 17:27:42.159 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
2025-11-05 17:28:12.161 INFO (MainThread) [supervisor.updater] No Supervisor connectivity, delaying version fetch
2025-11-05 17:28:12.161 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
2025-11-05 17:28:42.162 INFO (MainThread) [supervisor.updater] No Supervisor connectivity, delaying version fetch
2025-11-05 17:28:42.163 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
