Nextion - question on receiving sensordata in home assistant
I have Nextion display prepared via the editor. It is correctly connected to ESPhome. I can see in esphome that the buttons created on nextion when pressed generate an event in esphome:
[15:31:56][D][nextion:209]: Got touch page=0 component=6 type=RELEASE
[15:31:57][D][nextion:209]: Got touch page=0 component=6 type=RELEASE
[15:31:58][D][nextion:209]: Got touch page=0 component=6 type=RELEASE
[15:31:59][D][nextion:209]: Got touch page=0 component=7 type=RELEASE
[15:32:00][D][nextion:209]: Got touch page=0 component=9 type=RELEASE
[15:32:01][D][nextion:209]: Got touch page=0 component=2 type=RELEASE
[15:32:01][D][nextion:209]: Got touch page=0 component=3 type=RELEASE
I do not see (not in history, not in node-red) that the button is pressed. The esphome is correctly imported as an integration (and corresponding device & entity) in home assistant.
What could be wrong?
ps. this setup is exactly the same as another nextion display setup I have running except it is a 2.4 inch and this is a 3.2 inch.
the config:
esphome:
  platform: ESP8266
  board: d1_mini_pro
wifi:
  ssid: "IOTDOM"
  password: "12345678"
  use_address: 192.168.6.19
  domain: .me.local
  ap:
    ssid: "Nextionkap Fallback Hotspot"
    password: "0WQ3zCMCMlVV"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
  port: 80
uart:
  rx_pin: D7
  tx_pin: D5
  baud_rate: 9600
display:
  - platform: nextion
#    lambda: |-
#      it.set_wait_for_ack(false);
text_sensor:
  - platform: homeassistant
    entity_id: sensor.nextion_text1
binary_sensor:
  - platform: nextion
    page_id: 0
    component_id: 3
  - platform: nextion
    page_id: 0
    component_id: 2
  - platform: nextion
    page_id: 0
    component_id: 6
  - platform: nextion
    page_id: 0
    component_id: 7
  - platform: nextion
    page_id: 0
    component_id: 9
switch:
  - platform: uart
    data: 'dim=1'
  - platform: uart
    data: 'dim=20'
  - platform: uart
    data: 'dim=100'
  - platform: uart
    data: [0xFF, 0xFF, 0xFF]
All entiteis (binary sensors and switches) are created in home assistant.
I think you need to make the action in esphome.
This is waht i have and it works
  - platform: nextion
    page_id: 9
    component_id: 7
    filters:
      - delayed_on: 30ms
      - delayed_off: 30ms
    on_press:
      then:
        - homeassistant.service:
            service: light.toggle
              entity_id: light.kantoor_buro_lamp
So, what I have now done as a workaround is also ticked the
and then it works. But I would thus like to only use the “touch release event”…
Is that what your code does?
Not sure what this should do:
filters:
      - delayed_on: 30ms
      - delayed_off: 30ms
    on_press:
      then:
Maybe you will need the on_release instaid of on_press
More info on the filters
