Hi guys… So I just stumbled into the wonderful world of NFC tags… Now I naturaly want it all do work with just a scan…
But… Spotify seems to be a big showstopper for me…
Every evening when putting the son to bed, we turn off the light, turns on the heat, and puts a playlist on the google home speaker in his room…
So far I have the light/heat thing running fine with a tag… but what to do with Spotify…
I have added Spotify to my “Devices & Services” so I guess that should be running… But do I need to do something else for it to work on a named device… And what do I add it as? Right now the ligt goes as a “Call Service” the Heater as “Unit” but what should I do with the speeker?
Thanks both of you… Sadly I did not get any of the things to work…
If I install Spotcast, no sound are played from my Google home… ?
And if I use your solution @ RodgerDodger (took me a while to figure out that it was a complete automation yaml file you had made… ) The speaker makes a “beep - I have recived a command - Sound” but nothing playes, but the speaker is activted in some way…
