NFC tag issue with device_id
Hi folks, I’m facing with a problem using the device_id on tag_scanned event.
The following config is valid and works fine:
  - id: tag_scanned_test
    alias: Tag scanned test
    initial_state: true
    mode: single
      platform: event
      event_type: tag_scanned
      event_data:
        tag_id: da0e4742-ece7-41ff-b7f9-**********
    - service: script.turn_on
      entity_id: script.cross_platform_notification
        variables:
          title: "NFC tag scanned"
          message: "NFC tag da0e4742-ece7-41ff-b7f9-********** attivato"
          tag: nfc_notification_test
... but if use the device_id like the following:
    initial_state: true
    mode: single
      platform: event
      event_data:
        device_id: ************
        variables:
The automation isn’t executed anymore, it seems that the device_id isn’t valid, but I check twice and also pasted the value generated from the mobile app.
So… what’s the problem?
I have the same problem.
Did you find a solution for this? @naamah75
