i spent many hours on this issue:
I own a custom domain address.com which is properly bind to static IP: 220.1.2.3.
My system should work like this:
ha.address.com -> 220.1.2.3 -> 192.168.1.30:8123 (SSL) #HA Server - certificate from lets encrypt for ha.address.com + *.address.com
address.com -> 220.1.2.3 -> 192.168.1.50(:443) (SSL) #Web server - should took cert from 192.168.1.30
My NGINX Home Assistant SSL proxy configuration:
domain: ha.address.com
hsts: max-age=31536000; includeSubDomains
certfile: fullchain.pem
keyfile: privkey.pem
cloudflare: false
customize:
active: false
default: nginx_proxy_default*.conf
servers: nginx_proxy/*.conf
real_ip_from: []
configuration.yaml:
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24 # IP range for Nginx Proxy in Docker network
- 192.168.1.0/24 # Nginx running in local network
I am running HA on HA Yellow.
I can see the fullchain.pem
and privkey.pem
in the /ssl
directory. I get the certificates through Lets Encrypt DNS method.
Why is my certificate not working? What am I doing wrong? How should I change the NAT Rules on the router?
Thank you,
Michal
