Nginx Proxy Manager - Port in use error/web UI not launching
Failed to start addon
Port ‘80’ is already in use by something else on the host.
Just installed and this popup shows when I try to run. After setting it to any other port, the web UI still doesn’t launch. Unsure what to do here.
I am using DuckDNS with HA Supervised.
It’s only say that port 80 is in use. You have to check what is using port 80.
