Nginx server with home assistant (not the proxy server)
Anyone know if I could run nginx server along side home assistant on the same pi4?
…>Ed “Mike”
Yes. HA front end runs on port 8123, so as long as nginx is not trying to listen of that port then it should be fine. Obviously if you are running HAOS, you would need an addon for this but if direct or in a container, no issue.
Thx for the reply. Any instructions from somebody that has done this?
How have you got HA installed on you PI?
Hi, installed on ssd using Raspberry Pi Imager.
So you have hasos. In which case you would need this as an addon. Quick google returned no available addon for just nginx. Maybe someone knows of one.
