Recently I somehow lost access to all my Nginx hosts. Nothing in the configuration has changed. Now I would like to set it up again.
I’m running a Nginx proxy server in proxmox. I can access the web UI fine.
In Nginx, I add a proxy host:
domain name: www.domainname.nl
scheme: http
IP: 192.168.1.131
port: 8123
block common exploits enabled
websockets support enabled
then I add my custom SSL certificate which is valid till august this year by uploading the 3 certificate files that my domain provider has provided (cabundle.crt, certificate.crt, certificate.key)
In the proxy host I just created, I then select this certificate and enable “force SSL” and click save.
When I visit www.domainname.nl, I receive a “secure connection failed” error (Firefox). When I use Edge, I can continue. I then see the Nginx “congratulations!” page. For some reason it is not forwarding me to the internal IP that I have set.
I have forwarded both port 80 and 443 to the IP where Nginx is running.
How do I troubleshoot this issue from here? Thanks in advance!
Can you post your NGINX config in a code block ?
edit: When I disable “force SSL”, it works! I do want a secure connection of course, so this is not really a solution…
configuration.yaml:
http:
use_x_forwarded_for: true
trusted_proxies:
- 192.168.1.104 # IP of Nginx LXC container
# ip_ban_enabled: true
# login_attempts_threshold: 5
homeassistant:
external_url: https://www.mydomain.nl
internal_url: http://192.168.1.131:8123
I have changed the domain name in this code for privacy reasons. Other than that, here’s the content of the Nginx conf file
I also double checked that the certificate files are in the specified location.
# www.mydomain.nl
map $scheme $hsts_header {
https "max-age=63072000; preload";
server {
set $forward_scheme http;
set $server "192.168.1.131";
set $port 8123;
listen 80;
listen [::]:80;
listen 443 ssl;
listen [::]:443 ssl;
server_name www.mydomain.nl;
http2 off;
# Custom SSL
ssl_certificate /data/custom_ssl/npm-16/fullchain.pem;
ssl_certificate_key /data/custom_ssl/npm-16/privkey.pem;
# Block Exploits
include /etc/nginx/conf.d/include/block-exploits.conf;
# Force SSL
include /etc/nginx/conf.d/include/force-ssl.conf;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $http_connection;
proxy_http_version 1.1;
access_log /data/logs/proxy-host-3_access.log proxy;
error_log /data/logs/proxy-host-3_error.log warn;
location / {
# Proxy!
include /etc/nginx/conf.d/include/proxy.conf;
# Custom
include /data/nginx/custom/server_proxy[.]conf;
OK, but then what is in:
