Nginx showing up in logs when it is not installed
I had Nginx and it was not working due to how things are configured for my home assistant. I have it installed in Virtual Box.
I uninstalled Nginx, but for some reason it shows up in some logs for other apps.
Logs from Adguard.
2026/08/16 15:51:46.961989 [info] addrproc: processing addresse
[15:51:47] INFO: Starting NGinx…
[15:51:47] INFO: Successfully send discovery information to Home Assistant.
s6-rc: info: service discovery successfully started
Nginx shows as starting in Traccar, multiapp proxy, bookstack etc… It does not do it for every app. I did not look at the logs for every app installed.
I only have 10 apps installed. Would my router or Hue lighting that are connected to HA, pull that in some how?
I think HAOS use NGinX internally to share ports with apps that need network access and most do that.
