my no-ip cert expired after a year, so I renewed it, downloaded the new full chain pem file, put it in the ssl folder via file editor, but nothing has changed. I still can’t get to home assistant from the no-ip DNS name, and if I check the cert in my browser it says it is expired.
I even renamed the pem file in the ssl folder expecting something in nginx to break or log an error, but I don’t see anything.
i did check the logs, but they aren’t very verbose, and no errors.
I’m not sure what the permissions should be, I copied the file in using the Hile Editor.
