I have just updated my HA setup, (though I do not think this addon), and the addon now gives the following error and I cannot access via HTTPS
[INFO] Running nginx...
nginx: [emerg] BIO_new_file("/ssl/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/ssl/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
config is
"domain": "ha.borpin.net",
"certfile": "fullchain.pem",
"keyfile": "privkey.pem",
"hsts": "max-age=31536000; includeSubDomains",
"customize": {
"active": false,
"default": "nginx_proxy_default*.conf",
"servers": "nginx_proxy/*.conf"
Server is setup thus;
root@DietPi-V6-HA:/usr/share/hassio/ssl# ls -la
total 8
drwxr-xr-x 2 root root 4096 Aug 7 11:02 .
drwxr-xr-x 10 root root 4096 Jun 21 22:44 ..
lrwxrwxrwx 1 root root 44 Jun 21 23:01 cert.pem -> /etc/letsencrypt/live/ha.borpin.net/cert.pem
lrwxrwxrwx 1 root root 45 Jun 21 23:01 chain.pem -> /etc/letsencrypt/live/ha.borpin.net/chain.pem
lrwxrwxrwx 1 root root 49 Jun 21 23:02 fullchain.pem -> /etc/letsencrypt/live/ha.borpin.net/fullchain.pem
lrwxrwxrwx 1 root root 47 Jun 21 23:02 privkey.pem -> /etc/letsencrypt/live/ha.borpin.net/privkey.pem
root@DietPi-V6-HA:/usr/share/hassio/ssl# certbot certificates
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Found the following certs:
Certificate Name: ha.borpin.net
Domains: ha.borpin.net
Expiry Date: 2019-09-19 19:44:52+00:00 (VALID: 43 days)
Certificate Path: /etc/letsencrypt/live/ha.borpin.net/fullchain.pem
Private Key Path: /etc/letsencrypt/live/ha.borpin.net/privkey.pem
It worked quite happily before the update.
It looks like it cannot follow the symlinks to the certificates.
If I copy the certificates and update the config to the copied certificates it works.
-rw-r--r-- 1 root root 3550 Aug 7 11:53 fullchain2.pem
-rw-r--r-- 1 root root 1704 Aug 7 11:53 privkey2.pem
Is this a bug? I note that using the Samba addon, the linked files are not listed on my windows machine either (though I do not know if this is a new situation).
