Nibe heat pump - Example setup
Hi!
I’ve recently hooked up my Nibe heat pump (F750) to Home Assistant using the Nibe integration and an esphome device. Everything is working smoothly.
I went in this without thinking and now that it is connect, I don’t really know what to do with it so am looking for some examples, both in dashboard and automations.
Is there anyone running this integration that wouldn’t mind to share his/her setup?
I am using a heat curve to steer it’s heat and it’s just a set once and never look at it again approach.if it does happen to get too cold in the house we just fire up the woodstove to compensate rather than adjust the curve.
For warm water I’m using a time based schema where i basically turn off the pump’s hot water between 15:00 and 24:00 every day. It works for our needs.
I will probably change this last thing by removing that schema on the pump itself, and just toggle it from HA based on electricity prices, time of day and the heat of the water. But here I’m struggling to find the correct entity to interact with, for example “select.hot_water_comfort_mode_47041” is the mode, but there is no “off” mode.
Any examples are greatly appreciated! thanks!
Hi
I am also looking for a off mode. I have a S1255. For now trying to use holiday mode and in the pump block heating and hotwater when on holiday.
Let me know if you find a way
/T
