Current state:
Nibe F1245 PC → Modbus 40 → ATC107N → Moxa NPort P5150A
Using Node-RED I have a Flex Getter Node with the following settings for the Server:
I’m able to read and write the Modbus registers.
Future state:
I want to use the Nibe Heat Pump integration.
This integration has the option to use a Modbus RTU connection.
However when I enter the serial port used in the Node-Red configuration (/dev/ttyr03) I have no luck.
Do I need to enter something else or is my configuration not supported?
