Niko Battery switch multi button (Z2M / ZHA) Custom and Light mode [552-720X1][552-720X2][552-720X4]
strange i re-imported an reloaded al yaml.
I re-imorted again:
Dimming doesn’t work anymore, double click doesn’t work, single click works
2026-02-26 22:27:17.696 WARNING (MainThread) [niko_debug.a] A: first_press — trigger=z2m_button, raw=off_top_left, first_button=1, first_action=off, ts=1772141237.695013
2026-02-26 22:27:17.703 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=8, raw=, platform=mqtt
2026-02-26 22:27:17.998 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=True, elapsed_ms=303, raw=timeout, platform=none
2026-02-26 22:27:18.000 WARNING (MainThread) [niko_debug.c] C: second_press — second_action=none, second_button=0
2026-02-26 22:27:18.001 WARNING (MainThread) [niko_debug.d] D: double_click_check — second_action=none, first_action=off, second_button=0, first_button=1, result=False
2026-02-26 22:27:19.214 WARNING (MainThread) [niko_debug.a] A: first_press — trigger=z2m_button, raw=on_top_left, first_button=1, first_action=on, ts=1772141239.212969
2026-02-26 22:27:19.219 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=6, raw=, platform=mqtt
2026-02-26 22:27:19.376 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=164, raw=, platform=mqtt
2026-02-26 22:27:19.515 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=True, elapsed_ms=302, raw=timeout, platform=none
2026-02-26 22:27:19.517 WARNING (MainThread) [niko_debug.c] C: second_press — second_action=none, second_button=0
2026-02-26 22:27:19.518 WARNING (MainThread) [niko_debug.d] D: double_click_check — second_action=none, first_action=on, second_button=0, first_button=1, result=False
2026-02-26 22:27:21.003 WARNING (MainThread) [niko_debug.a] A: first_press — trigger=z2m_button, raw=on_top_left, first_button=1, first_action=on, ts=1772141241.002482
2026-02-26 22:27:21.011 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=9, raw=, platform=mqtt
2026-02-26 22:27:21.195 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=192, raw=, platform=mqtt
2026-02-26 22:27:21.305 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=True, elapsed_ms=303, raw=timeout, platform=none
2026-02-26 22:27:21.308 WARNING (MainThread) [niko_debug.c] C: second_press — second_action=none, second_button=0
2026-02-26 22:27:21.309 WARNING (MainThread) [niko_debug.d] D: double_click_check — second_action=none, first_action=on, second_button=0, first_button=1, result=False
2026-02-26 22:27:22.054 WARNING (MainThread) [niko_debug.a] A: first_press — trigger=z2m_button, raw=on_top_left, first_button=1, first_action=on, ts=1772141242.053268
2026-02-26 22:27:22.062 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=9, raw=, platform=mqtt
2026-02-26 22:27:22.200 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=147, raw=, platform=mqtt
2026-02-26 22:27:22.357 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=True, elapsed_ms=304, raw=timeout, platform=none
2026-02-26 22:27:22.360 WARNING (MainThread) [niko_debug.c] C: second_press — second_action=none, second_button=0
2026-02-26 22:27:22.361 WARNING (MainThread) [niko_debug.d] D: double_click_check — second_action=none, first_action=on, second_button=0, first_button=1, result=False
2026-02-26 22:27:24.049 WARNING (MainThread) [niko_debug.a] A: first_press — trigger=z2m_button, raw=off_bottom_right, first_button=4, first_action=off, ts=1772141244.047928
2026-02-26 22:27:24.064 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=16, raw=, platform=mqtt
2026-02-26 22:27:24.350 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=True, elapsed_ms=302, raw=timeout, platform=none
2026-02-26 22:27:24.353 WARNING (MainThread) [niko_debug.c] C: second_press — second_action=none, second_button=0
2026-02-26 22:27:24.354 WARNING (MainThread) [niko_debug.d] D: double_click_check — second_action=none, first_action=off, second_button=0, first_button=4, result=False
2026-02-26 22:27:30.635 WARNING (MainThread) [niko_debug.a] A: first_press — trigger=z2m_button, raw=on_top_left, first_button=1, first_action=on, ts=1772141250.634369
2026-02-26 22:27:30.641 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=7, raw=, platform=mqtt
2026-02-26 22:27:30.779 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=144, raw=, platform=mqtt
2026-02-26 22:27:30.938 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=True, elapsed_ms=304, raw=timeout, platform=none
2026-02-26 22:27:30.941 WARNING (MainThread) [niko_debug.c] C: second_press — second_action=none, second_button=0
2026-02-26 22:27:30.942 WARNING (MainThread) [niko_debug.d] D: double_click_check — second_action=none, first_action=on, second_button=0, first_button=1, result=False
2026-02-26 22:27:32.528 WARNING (MainThread) [niko_debug.e.1u] E: dim_start — button=1, direction=up, trigger=z2m_button, action=brightness_move_up_top_left, mode=dim, has_light=True, step_size=12, count=22
2026-02-26 22:27:36.485 WARNING (MainThread) [niko_debug.e.1u] E: dim_start — button=1, direction=up, trigger=z2m_button, action=brightness_move_up_top_left, mode=dim, has_light=True, step_size=12, count=22
2026-02-26 22:27:40.301 WARNING (MainThread) [niko_debug.a] A: first_press — trigger=z2m_button, raw=on_top_left, first_button=1, first_action=on, ts=1772141260.299731
2026-02-26 22:27:40.308 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=8, raw=, platform=mqtt
2026-02-26 22:27:40.602 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=True, elapsed_ms=302, raw=timeout, platform=none
2026-02-26 22:27:40.604 WARNING (MainThread) [niko_debug.c] C: second_press — second_action=none, second_button=0
2026-02-26 22:27:40.605 WARNING (MainThread) [niko_debug.d] D: double_click_check — second_action=none, first_action=on, second_button=0, first_button=1, result=False
2026-02-26 22:27:42.550 WARNING (MainThread) [niko_debug.e.1d] E: dim_start — button=1, direction=down, trigger=z2m_button, action=brightness_move_down_top_left, mode=dim, has_light=True, step_size=12, count=22
2026-02-26 22:27:52.518 WARNING (MainThread) [niko_debug.a] A: first_press — trigger=z2m_button, raw=off_top_left, first_button=1, first_action=off, ts=1772141272.517179
2026-02-26 22:27:52.525 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=8, raw=, platform=mqtt
2026-02-26 22:27:52.821 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=True, elapsed_ms=304, raw=timeout, platform=none
2026-02-26 22:27:52.824 WARNING (MainThread) [niko_debug.c] C: second_press — second_action=none, second_button=0
2026-02-26 22:27:52.825 WARNING (MainThread) [niko_debug.d] D: double_click_check — second_action=none, first_action=off, second_button=0, first_button=1, result=False
2026-02-26 22:27:54.898 WARNING (MainThread) [niko_debug.a] A: first_press — trigger=z2m_button, raw=on_top_left, first_button=1, first_action=on, ts=1772141274.896921
2026-02-26 22:27:54.903 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=6, raw=, platform=mqtt
2026-02-26 22:27:55.199 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=True, elapsed_ms=303, raw=timeout, platform=none
2026-02-26 22:27:55.202 WARNING (MainThread) [niko_debug.c] C: second_press — second_action=none, second_button=0
2026-02-26 22:27:55.203 WARNING (MainThread) [niko_debug.d] D: double_click_check — second_action=none, first_action=on, second_button=0, first_button=1, result=False
2026-02-26 22:27:58.386 WARNING (MainThread) [niko_debug.e.1d] E: dim_start — button=1, direction=down, trigger=z2m_button, action=brightness_move_down_top_left, mode=dim, has_light=True, step_size=12, count=22
2026-02-26 22:28:04.548 WARNING (MainThread) [niko_debug.a] A: first_press — trigger=z2m_button, raw=off_top_left, first_button=1, first_action=off, ts=1772141284.547199
2026-02-26 22:28:04.554 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=7, raw=, platform=mqtt
2026-02-26 22:28:04.752 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=205, raw=, platform=mqtt
2026-02-26 22:28:04.849 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=True, elapsed_ms=302, raw=timeout, platform=none
2026-02-26 22:28:04.852 WARNING (MainThread) [niko_debug.c] C: second_press — second_action=none, second_button=0
2026-02-26 22:28:04.853 WARNING (MainThread) [niko_debug.d] D: double_click_check — second_action=none, first_action=off, second_button=0, first_button=1, result=False
2026-02-26 22:28:06.314 WARNING (MainThread) [niko_debug.a] A: first_press — trigger=z2m_button, raw=off_top_left, first_button=1, first_action=off, ts=1772141286.313487
2026-02-26 22:28:06.319 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=6, raw=, platform=mqtt
2026-02-26 22:28:06.499 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=False, elapsed_ms=185, raw=, platform=mqtt
2026-02-26 22:28:06.617 WARNING (MainThread) [niko_debug.b] B: wait_result — timed_out=True, elapsed_ms=303, raw=timeout, platform=none
2026-02-26 22:28:06.620 WARNING (MainThread) [niko_debug.c] C: second_press — second_action=none, second_button=0
2026-02-26 22:28:06.621 WARNING (MainThread) [niko_debug.d] D: double_click_check — second_action=none, first_action=off, second_button=0, first_button=1, result=False
:warning: New Update Available (2026.03.1)
Niko Battery Switch v2026.03.1: Fix dim-stop and double-click reliability for Z2M
What’s Fixed:
  • All Z2M MQTT triggers switched to action sub-topic (zigbee2mqtt/device/action) — Z2M only publishes there on real actions, so spurious messages (linkquality, battery updates, extra Zigbee frames) never reach the blueprint; double-click window is now fully available for the second press
  • Dim-stop broken on Z2M 4-button — spurious MQTT messages fired the wait prematurely causing Thread 1 to exit before brightness_stop arrived; replaced single wait with a repeat:while loop
  • Button 3 DOWN dim-stop never worked — stop condition was a separate parallel branch that always ran before the wait completed and never set the stop flag
Upgrade Instructions:
  • Reload your Niko automations after updating
It looks like you did it!
Single click works, double click works, dimming works!
Great to hear. Enjoy!
