Niko Home Control - roller shutter support
the devs added in the update of this month (may 2023)… “brightness control for the Niko Home Control integration”, which is GREAT!, my lights finally work (even on/off works now), which was one of my issues.
So, thank you!
But i would like to ask the devs to add a few lines in the code to make my shutters also work :grinning: , the shutters are discovered, but only support on/off and this gives an error when pressing the button. (failed to call service light/turn_on. NOT FOUND)
i would also be willing to help out by testing if that could be of any help.
Thank you
I have the exact same problem! Does it work by now for you? Im still not able to fix it! Trying for months now!
