I just got a new Niu NQi Sport and intend to create a custom component & possibly a custom card for Home Assistant. Before I start I’m keen to see how much interest there is in this.
Also, I’ll need a few people to help with testing so that we can check everything works properly and see which devices (hopefully all) it works with.
Post a reply below if you are interested in testing &/or helping develop this, and like the post to give an indication that you are interested in this becoming a reality.
@Phill_Healey : i’m interested ! (by this old conversation)
I have a Niu N1S and i tested and contributed to @marcelwestrahome’s component.
I have added last track sensor to know information about the last ride
Hi @marcelwestrahome ! first of all thanks for starting this project! I just got my new NIU and I tried to use your integration but it keeps giving me this error, can you help me out with is?
(I copy pasted the sensor yaml and changed values according to my moto)
Logger: homeassistant.components.sensor
Source: custom_components/niu/sensor.py:425
Integration: Sensor (documentation, issues)
First occurred: 12:23:11 (1 occurrences)
Last logged: 12:23:11
Error while setting up niu platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 249, in _async_setup_platform
await asyncio.shield(task)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/niu/sensor.py", line 392, in setup_platform
NiuSensor(
File "/config/custom_components/niu/sensor.py", line 499, in __init__
self._state = self._data_bridge.dataDist(self._id_name)
File "/config/custom_components/niu/sensor.py", line 425, in dataDist
return self._dataMoto["data"]["lastTrack"][id_field]
KeyError: 'distance'
uhh no I tried that also, the entity gets an link, but do not know how to show this.
I am using this component to show the battery and to turn off the loader (with a wifi switch) when the battery is full
Is the Niu Scooter integration still alive? I’m trying to install it but having problems. I’m wondering if it is still working could you help me get it up and running?
I’ve tried installing via HACS and by copying the custom_components folder. I have the necassary platform sensor in configuration.yaml and there are no devices or entities showing up in HA. Any assistance would be much appreciated
