Since upgrading to the latest version of HA, I keep getting this in my home-assistant.log
File "/usr/lib/python3.5/asyncio/tasks.py", line 241, in _step
result = coro.throw(exc)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/__init__.py", line 693, in async_device_tracker_scan
found_devices = yield from scanner.async_scan_devices()
File "/usr/lib/python3.5/asyncio/futures.py", line 361, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 296, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 274, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/nmap_tracker.py", line 87, in scan_devices
self._update_info()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/util/__init__.py", line 296, in wrapper
result = method(*args, **kwargs)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/nmap_tracker.py", line 110, in _update_info
scanner = PortScanner()
File "/home/homeassistant/.homeassistant/deps/nmap/nmap.py", line 131, in __init__
os.getenv('PATH')
nmap.nmap.PortScannerError: 'nmap program was not found in path. PATH is : /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin'
However
/usr/bin/nmap
PATH contains /usr/bin and NMAP is definitely there because it was working before the upgrade and works from the command line.
Am I missing something in the 0.39 docs or should I report this as a bug?
