Nmap showing all devices home then not_home every couple seconds
Nmap recently started showing all devices home then not_home every couple seconds and switching back and forth! Had made some changes to the system and thought it was me so wiped and built from scratch then dropped my config back and is still happening… Help! I am on 0.96.5 build
What is the consider home interval set to?
consider_home: 180
but is happening every 5 to 20 seconds all at once on all nmap devices
That would tend to suggest an issue with NMAP.
You can report an issue here:
There does not seem to be a relevant one open already.
This was an issue with a conflicting Icloud3 custom component. Placing the nmap trackers above the icloud3 tracker was the fix.
