No access to web portal
Is there a way to stop nginx and duckdns from the HomeAssistant shell?
I can no longer access home-assistant portal. No idea why.
Ping no problem.
Access to http://homeassistant.local:4357/
Home Assistant observer
Supervisor: Connected
Supported: Supported
Healthy: Healthy
Did you try with https:// ?
Yes, doesn’t work.
“Connection failed”
Basically, I’ve already given up because I haven’t been able to do it for 8 hours. The worst thing, by the way, is vi-Editor.
But now I can’t find a Proxmox helper script either to create a new HAOS-VM.
Ah right. Thanks. I had to look at HAOS VM but I was looking for Proxmox VM.
HomeAssistant has exhausted me.
If you are running NGinX, then your HA service is probably only running HTTP and should be accessible on http://homeassistant.local:8123, which is the direct connection bypassing NGinX.
I have tried now to create a new HAOS VM but this doesn’t worked too because no access to IP of newly created HAOS VM.
Router restarted few times, Computer too, from mobile-network, tried with different computer before with old not working HAOS VM
Prob some network stuff and need to wait few days.
Edit: http://homeassistant.local:8123 tried too before but same “Error: Connection interrupted”
