No Add Node In Z-Wave
Hi, I’m new to this new home assistant (I’ve been using the old one all this time), I’ve successfully installed Hassio, and successfully add my Z-Wave stick, but there’s no “ADD NODE” inside the Z-Wave Network, what did I missed ?
Thanks before.
“Start Network” basically starts your Z-Wave network. You can’t add/remove nodes to a network that’s not ‘started’
Hi, thank you, the problem has been solved, actually I wrote the wrong USB path.
