No autocomplete for new entities without NR restart?
In the last couple months (not sure which update caused this) I have noticed that NR no longer will autocomplete new entities unless I restart the add-on or wait a day. It used to be that they would pop-up immediately after creating the entities. I’m adding a bunch of z-wave devices and having to do a restart of NR after creation of each one and it’s really annoying. I went through the HASS supervisor, core and NR logs and don’t see any errors. Is there somthing broken with my configuration or is this by design?
I should clarify that if I first copy the exact name of the entity and paste that into the NR flow I’m creating, while it doesn’t autocomplete it, it will still work.
Try going to your server config, any HA node click the pencil next to the server. Uncheck cache auto complete. Update save and deploy, then restart nodered.
I tried this and then added a new device and it didn’t change hte behavior. I didn’t restart the NR add-on after making the change – would that matter?
