No connection relay matter to HA
Goodmorning, its days that try to connect a relay matter apple home (1CH switch module).
I connected the relay to the apple home app so my relay has an ip and is connected to the wifi. I remove the relay from apple home, the relay continues to be connected to the wifi but HA does’t find the new device to add.
I don’t understand where I’m going wrong.
Can someone help me?
I am not sure how the removal of a device works, but once a device is enrolled in aMarter fabric, then the QR code on the device can’t be used anymore.
You will then either have to share the device with a QR code from the currently connected Matter fabric or factory reset the device completely to make the original QR code work again.
ok, for other devices I read in the forums to do as I wrote and I managed to pair them. Not this one, I can also reset the Matter device then how do I pair it to HA via QR code?
ohhh nice, thank you. its very easy.
Thank you so much and sorry
