No history or registry after updates
Since the last update (I think core) a couple of days ago… I no longer have a history of any entity or history log tabs in the side menu. This morning another update jumped (I thought it might be to correct it) but nothing has changed.
Does anyone know if I should do something?
Hello jbega,
I am not certain if it will help, but the next thing I would is reboot the host, then look in the logs and see if you can find something in the logs if it’s still weird.
Thanks for answering! I have restarted and in n config/system/logs checked both the core and supervisor as host, apparently I don’t see any related errors
You would be looking for something about database errors or database rebuilding or something like that.
Thanks for the advice, that’s what I did but I didn’t see anything in the records. I had to load a backup from January.
I have the same issue after upgrading on 6 Feb. to version 2025.2 from 2025.1.4. No more history to show. Did reboot and upgrades to latest version.
How can I fix this?
Checked log files. In supervisor log file I found this:
Supervisor Log
2025-02-06 19:55:01.191 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2025.2.0
2025-02-06 19:55:01.194 INFO (MainThread) [supervisor.docker.interface] Updating image Package yellow-homeassistant · GitHub to Package yellow-homeassistant · GitHub
2025-02-06 19:55:01.194 INFO (MainThread) [supervisor.docker.interface] Downloading docker image Package yellow-homeassistant · GitHub with tag 2025.2.0.
2025-02-06 19:57:50.120 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-02-06 19:57:50.121 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-02-06 19:57:50.121 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-02-06 19:57:50.122 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-02-06 19:57:50.123 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-02-06 19:57:50.124 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-02-06 19:57:50.126 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2025-02-06 19:57:50.226 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-02-06 19:57:50.229 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-02-06 19:57:50.230 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-02-06 19:57:50.231 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-02-06 19:57:50.231 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-02-06 19:57:50.232 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-02-06 19:57:50.792 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-02-06 19:57:50.793 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-02-06 19:57:50.793 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2025-02-06 19:58:11.240 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping homeassistant application
2025-02-06 19:58:11.453 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API for a0d7b954_nodered closed
2025-02-06 19:58:22.878 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning homeassistant application
2025-02-06 19:58:23.341 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2025-02-06 19:58:23.793 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant Package yellow-homeassistant · GitHub with version 2025.2.0
2025-02-06 19:58:23.794 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2025-02-06 19:58:43.101 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-02-06 19:58:43.438 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-02-06 19:58:43.843 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-02-06 19:58:43.867 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state=‘NOT_RUNNING’, offline_db_migration=False)
2025-02-06 19:59:15.450 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state=‘RUNNING’, offline_db_migration=False)
2025-02-06 19:59:15.450 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
2025-02-06 19:59:15.451 INFO (MainThread) [supervisor.homeassistant.core] Successfully started Home Assistant 2025.2.0
2025-02-06 19:59:15.546 INFO (SyncWorker_2) [supervisor.docker.manager] Cleanup images: [‘Package yellow-homeassistant · GitHub’]
2025-02-06 19:59:16.865 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2025-02-06 19:59:16.886 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
2025-02-06 19:59:16.991 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
2025-02-06 20:29:05.389 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-02-06 20:37:57.118 INFO (MainThread) [supervisor.host.info] Updating local host information
2025-02-06 20:37:58.291 INFO (MainThread) [supervisor.host.services] Updating service information
2025-02-06 20:37:58.306 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-02-06 20:37:58.652 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-02-06 20:37:58.689 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2025-02-06 20:57:50.805 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-02-06 20:57:50.805 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-02-06 20:57:50.806 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-02-06 20:57:50.806 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-02-06 20:57:50.807 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-02-06 20:57:50.911 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-02-06 20:57:50.912 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2025-02-06 20:57:51.003 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-02-06 20:57:51.004 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-02-06 20:57:51.005 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-02-06 20:57:51.005 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-02-06 20:57:51.006 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-02-06 20:57:51.006 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-02-06 20:57:51.373 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-02-06 20:57:51.374 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-02-06 20:57:51.374 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
As far as I can see no errors.
Thanks for the support
Just set back a copy of last database that was working. Noticed that I also downgraded HA to 2025.1.4…
Did I do something wrong or is it not possible to just restore database. I used the System → backup then restore option .
After downgrade still no history.
When rebooting/starting:
Logger: homeassistant.helpers.translation
Source: helpers/translation.py:226
First occurred: 15:04:09 (1 occurrences)
Last logged: 15:04:09
Failed to load integration for translation: Integration ‘resources’ not found.
And this one:
Logger: homeassistant.setup
Source: setup.py:269
First occurred: 15:04:15 (1 occurrences)
Last logged: 15:04:15
Setup failed for ‘resources’: Integration not found.
This I have since 7 or 8 month.
Can someone help me please? I upgraded back to 2025.2 and still no history. How can I fix this?
Have been searching but not found a solution, is there a way to start the history recording? Anyone else has this issue?
Any help much appreciated,
Thank you very much
