No identity sensor with iobroker eufysecurity
HI,
For use eufysecurity cam, I use io broker. but in HA I have this error:
Logger: homeassistant.components.sensor
Source: helpers/template.py:1472
Integration: Capteur (documentation, issues)
First occurred: 13:15:06 (2 occurrences)
Last logged: 13:15:06
Error adding entities for domain sensor with platform rest
Error while setting up rest platform for sensor
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 442, in async_add_entities
    await asyncio.gather(*tasks)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 717, in _async_add_entity
    await entity.add_to_platform_finish()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 806, in add_to_platform_finish
    await self.async_added_to_hass()
  File "/usr/src/homeassistant/homeassistant/components/rest/entity.py", line 42, in async_added_to_hass
    self._update_from_rest_data()
  File "/usr/src/homeassistant/homeassistant/components/rest/sensor.py", line 173, in _update_from_rest_data
    value = self._value_template.async_render_with_possible_json_value(
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 625, in async_render_with_possible_json_value
    return _render_with_context(self.template, compiled, **variables).strip()
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2007, in _render_with_context
    return template.render(**kwargs)
  File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 1301, in render
    self.environment.handle_exception()
  File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 936, in handle_exception
    raise rewrite_traceback_stack(source=source)
  File "<template>", line 1, in top-level template code
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1790, in forgiving_int_filter
    raise_no_default("int", value)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1472, in raise_no_default
    raise ValueError(
ValueError: Template error: int got invalid input '{
  "error": "command getPlainvalue unknown",
  "getPlainValue": "http://192.168.1.99:8087/getPlainValue/stateID",
  "get": "http://192.168.1.99:8087/get/stateID/?prettyPrint",
  "getBulk": "http://192.168.1.99:8087/getBulk/stateID1,stateID2/?prettyPrint",
  "set": "http://192.168.1.99:8087/set/stateID?value=1&prettyPrint",
  "toggle": "http://192.168.1.99:8087/toggle/stateID&prettyPrint",
  "setBulk": "http://192.168.1.99:8087/setBulk?stateID1=0.7&stateID2=0&prettyPrint",
  "setValueFromBody": "http://192.168.1.99:8087/setValueFromBody?stateID1",
  "objects": "http://192.168.1.99:8087/objects?pattern=system.adapter.admin.0*&prettyPrint",
  "states": "http://192.168.1.99:8087/states?pattern=system.adapter.admin.0*&prettyPrint",
  "search": "http://192.168.1.99:8087/search?pattern=system.adapter.admin.0*&prettyPrint",
  "query": "http://192.168.1.99:8087/query/stateID1,stateID2/?dateFrom=2019-06-06T12:00:00.000Z&dateTo=2019-06-06T12:00:00.000Z&noHistory=false&aggregate=minmax&count=3000&prettyPrint"
}' when rendering template '{% set v = value | replace("","")|int %} {{ {0: "Away",
    1: "Home",
    2: "Schedule",
    3: "Custom1",
    4: "Custom2",
    5: "Custom3",
    47: "Geofence",
    63: "Disarmed"}[v] | default("Unknown state:" + (value|urlencode)) }}' but no default was specified
My configuration.yaml:
Can you help me please?
In fact it’s getPlainValue and not getPlainvalue
