No internal connection
I’m using the Home Assistant Companion App for a while now.
Internally, the IP address is fixed.
External connection is done via a vpn tunnel and an Apache proxy.
So far, this was always working. Now, all of my devices can’t connect internally with the app anymore.
When I remove the internal URL it is working as the external URL is used.
When I connect to the internal URL by browser, it is working.
Beside of updates, no changes in Home Assistant
Restart of Home Assistant (Rpi4) and clients didn’t help.
Can’t see any errors in the logs.
Any idea what might be wrong?
Thank you very much.
