My HA installation is messed up somehow. Running from Docker container. I can access internally using the 8123 port but when I try to access externally using HTTPS, all I get is “unable to connect and click to retry”. It was working just fine. I updated all the containers.
Running from latest 2023.3.4. Tried going backwards a few versions but same thing.
When I attempt to connect from external HTTPS address, I get these in the logs:
2023-03-15 18:07:06.497 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 332, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp/_http_parser.pyx", line 551, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message="Bad status line 'Invalid method encountered'"
2023-03-15 18:07:06.510 ERROR (MainThread) [aiohttp.server] Error handling request
2023-03-15 18:07:06.645 ERROR (MainThread) [aiohttp.server] Error handling request
2023-03-15 18:07:06.656 ERROR (MainThread) [aiohttp.server] Error handling request
2023-03-15 18:07:06.972 ERROR (MainThread) [aiohttp.server] Error handling request
2023-03-15 18:07:06.979 ERROR (MainThread) [aiohttp.server] Error handling request
2023-03-15 18:07:06.988 ERROR (MainThread) [aiohttp.server] Error handling request
2023-03-15 18:07:07.006 ERROR (MainThread) [aiohttp.server] Error handling request
2023-03-15 18:07:07.692 ERROR (MainThread) [aiohttp.server] Error handling request
2023-03-15 18:07:07.702 ERROR (MainThread) [aiohttp.server] Error handling request
2023-03-15 18:07:09.488 ERROR (MainThread) [aiohttp.server] Error handling request
2023-03-15 18:07:09.497 ERROR (MainThread) [aiohttp.server] Error handling request
Internally the web GUI comes up just fine. SSL certificate shows valid externally. Proxied through NGINX (no changes made to that). No other changes made to my HA config either.
I see where others have had this web_protocol.py error but I have not found a solution to it.
Thanks!
-Tim
