I’ve been working on trying to get letsencrypt working so I can access Home Assistant outside of my network. I’m running on a nuc with ubuntu 16.04lts and docker. So far I’ve triple checked that ports 80 and 443 are open on my router. No matter what I try though letsencrypt comes back with failed authentication of http://mydomain.duckdns.org with a timeout. Does anyone have any ideas on whats going on?
What client are you using for LetsEncrypt? Did you remember to forward port 80 to the IP address of the host running that client?
./certbot-auto certonly --standalone --standalone-supported-challenges http-01 --email [email protected] -d YOURSUBDOMAIN.duckdns.org
I have been running that command and yes port 80 and 443 are both forwarded to the host.
The Let’s Encrypt community forum is probably the best place to get help. Most likely one of the following is true:
- Port 80 is blocked by your ISP
- Port 80 isn’t forwarded in your Docker environment
- Port 80 is forwarded to the wrong IP on your network
Could you elaborate on #2? I don’t recall ever doing anything with port 80 in my initial setup of docker.
In Docker you have to forward (expose) ports to containers.
hmm yeah I never did anything with port 80. Here is my docker compose file:
version: "2"
services:
portainer:
image: portainer/portainer
container_name: portainer
restart: always
command: --templates http://templates/templates.json
volumes:
- /var/run/docker.sock:/var/run/docker.sock
- /home/docker/portainer/data:/data
ports:
- "9000:9000"
environment:
- TZ=America/New_York
homeassistant:
container_name: home-assistant
restart: always
image: homeassistant/home-assistant:latest
devices:
- /dev/ttyUSB0:/dev/ttyUSB0
- /dev/ttyUSB1:/dev/ttyUSB1
- /dev/ttyACM0:/dev/ttyACM0
volumes:
- /home/docker/homeassistant:/config
- /etc/localtime:/etc/localtime:ro
- /home/docker/certs:/certs
network_mode: host
privileged: true
environment:
- PUID=1000
- PGID=999
See how you’ve got
ports:
- "9000:9000"
You need something similar for the container running Home Assistant I believe (though, I don’t use Docker)
