No media_player after reinstall
I’m having issues with media_players after changing my setup to SSD, they are all showing unavailable, also I notice remotes are also unavailable.
Here is a section of my log file
2020-04-11 22:18:16 ERROR (MainThread) [homeassistant.bootstrap] Error setting up integration cast - received exception
  File "/usr/src/homeassistant/homeassistant/setup.py", line 50, in async_setup_component
    return await task  # type: ignore
  File "/usr/src/homeassistant/homeassistant/setup.py", line 129, in _async_setup_component
    await async_process_deps_reqs(hass, config, integration)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 291, in async_process_deps_reqs
    hass, integration.domain
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 55, in async_get_integration_with_requirements
    hass, integration.domain, integration.requirements
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 99, in async_process_requirements
    if pkg_util.is_installed(req):
  File "/usr/src/homeassistant/homeassistant/util/package.py", line 44, in is_installed
    return version(req.project_name) in req
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3145, in __contains__
    return self.specifier.contains(item, prereleases=True)
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/specifiers.py", line 703, in contains
    item = parse(item)
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 31, in parse
    return Version(version)
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 200, in __init__
    match = self._regex.search(version)
TypeError: expected string or bytes-like object
If you require more info, please let me know.
Thanks.
Here’s another error I think is related.
Log Details (ERROR)
Logger: aiohttp.server
Source: components/cast/home_assistant_cast.py:4
First occurred: 11:30:35 PM (2 occurrences)
Last logged: 11:33:00 PM
Error handling request
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
    resp = await task
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 123, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 106, in delete
    result = await hass.config_entries.async_remove(entry_id)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 604, in async_remove
    unload_success = await self.async_unload(entry_id)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 704, in async_unload
    return await entry.async_unload(self.hass)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 272, in async_unload
    component = integration.get_component()
  File "/usr/src/homeassistant/homeassistant/loader.py", line 268, in get_component
    cache[self.domain] = importlib.import_module(self.pkg_path)
  File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 728, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/usr/src/homeassistant/homeassistant/components/cast/__init__.py", line 4, in <module>
    from . import home_assistant_cast
  File "/usr/src/homeassistant/homeassistant/components/cast/home_assistant_cast.py", line 4, in <module>
    from pychromecast.controllers.homeassistant import HomeAssistantController
ImportError: cannot import name 'HomeAssistantController' from 'pychromecast.controllers.homeassistant' (/usr/local/lib/python3.7/site-packages/pychromecast/controllers/homeassistant.py)
Hi, I find after an update the media players are not working but with a complete reboot all is fine again.
