No module pychromecast
Hi i get this error with the latest Home Assistant 0.110.0b3 release:
Unable to prepare setup for platform cast.media_player: Platform not found (No module named 'pychromecast.quick_play').
Any ideas why? It doesn’t discover casting devices any more. I also tried to specify them manually but it doesn’t work. i also deleted google cast from integrations and readded it.
I am having the same problem with 0.110.x stable releases.
Found a fix yet.
Is an issue already reported on GitHub?
in my case it was caused by the plex assistant plugin installed via hacs.
i disabled the plugin and it started working agian.
today i reinstalled the latest version of the plugin and seems ok.
Ah, the Spotcast plugin was the issue for me.
Thank you!
