No more transition/fade out on light.turn_off lately with zigbee dimmer switches
Hello everyone,
My lights used to gently fade out when using light.turn_off with Hue Dimmer Switch but it’s not the case anymore since last updates (Z2M and Home Assistant core).
Fade out works when I switch off / Toggle lights through the dashboard or Ikea Bilresa remotes configured with Matter but everything configured in Z2M shutdown everything without delay, so I guess Zigbee2MQTT is the culprit.
I’ll wait patiently for an update that will probably fix this but anyone can confirm the same behavior on his installation here ?
Thanks !
