No more ZWave device since this night
I do not have any ZWave device since this night. Tried several version 0.83.x … 0.84.x and none seems working.
The OZW_Log.txt just displays the following lines:
2018-12-26 11:56:37.029 Always, OpenZwave Version 1.4.3254 Starting Up
2018-12-26 11:57:04.075 Info, Setting Up Provided Network Key for Secure Communications
2018-12-26 11:57:04.075 Info, mgr,     Added driver for controller /dev/ttyUSB-ZStick-5G
2018-12-26 11:57:04.075 Info,   Opening controller /dev/ttyUSB-ZStick-5G
2018-12-26 11:57:04.075 Info, Trying to open serial port /dev/ttyUSB-ZStick-5G (attempt 1)
2018-12-26 11:57:04.076 Info, Serial port /dev/ttyUSB-ZStick-5G opened (attempt 1)
2018-12-26 11:57:04.077 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-12-26 11:57:04.077 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2018-12-26 11:57:04.077 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2018-12-26 11:57:04.077 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2018-12-26 11:57:04.077 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2018-12-26 11:57:04.077 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-12-26 11:57:05.077 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-12-26 11:57:05.077 Detail, contrlr, Removing current message
2018-12-26 11:57:05.077 Detail, contrlr, Notification: Notification - TimeOut
2018-12-26 11:57:05.080 Detail,
2018-12-26 11:57:05.080 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2018-12-26 11:57:06.081 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-12-26 11:57:06.081 Detail, contrlr, Removing current message
2018-12-26 11:57:06.081 Detail, contrlr, Notification: Notification - TimeOut
2018-12-26 11:57:06.082 Detail,
2018-12-26 11:57:06.082 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2018-12-26 11:57:07.083 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-12-26 11:57:07.083 Detail, contrlr, Removing current message
2018-12-26 11:57:07.083 Detail, contrlr, Notification: Notification - TimeOut
2018-12-26 11:57:07.085 Detail,
2018-12-26 11:57:07.085 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2018-12-26 11:57:08.085 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-12-26 11:57:08.086 Detail, contrlr, Removing current message
2018-12-26 11:57:08.086 Detail, contrlr, Notification: Notification - TimeOut
2018-12-26 11:57:08.090 Detail,
2018-12-26 11:57:08.090 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2018-12-26 11:57:09.091 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-12-26 11:57:09.091 Detail, contrlr, Removing current message
2018-12-26 11:57:09.091 Detail, contrlr, Notification: Notification - TimeOut
Main log display ZWave is stuck somewhere:
2018-12-26 12:02:04 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave not ready after 300 seconds, continuing anyway
2018-12-26 12:02:04 INFO (MainThread) [homeassistant.components.zwave] final network state: 0 Network is stopped
2018-12-26 12:02:04 INFO (Thread-3) [homeassistant.components.zwave] Z-Wave polling interval set to 60000 ms
Any idea?
My ZWave divice is a Z-Wave Plus Z-Stick GEN5 and does not even appear in the Zwave page. /dev/ttyUSB-ZStick-5G points well to /dev/ttyACM0 which is the ZWave stick, like seen in dmesg:
[    5.189458] usbcore: registered new interface driver brcmfmac
[    5.198532] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Here is the lsusb:
$ lsusb -v
Bus 001 Device 005: ID 0658:0200 Sigma Designs, Inc.
Couldn't open device, some information will be missing
Device Descriptor:
bLength                18
bDescriptorType         1
bcdUSB               2.00
bDeviceClass            2 Communications
bDeviceSubClass         0
bDeviceProtocol         0
bMaxPacketSize0         8
idVendor           0x0658 Sigma Designs, Inc.
idProduct          0x0200
bcdDevice            0.00
iManufacturer           0
iProduct                0
iSerial                 0
bNumConfigurations      1
Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           67
    bNumInterfaces          2
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
    (Bus Powered)
    MaxPower              100mA
    Interface Descriptor:
    bLength                 9
    bDescriptorType         4
    bInterfaceNumber        0
    bAlternateSetting       0
    bNumEndpoints           1
    bInterfaceClass         2 Communications
    bInterfaceSubClass      2 Abstract (modem)
    bInterfaceProtocol      1 AT-commands (v.25ter)
    iInterface              0
    CDC Header:
        bcdCDC               1.10
    CDC Call Management:
        bmCapabilities       0x00
        bDataInterface          1
    CDC ACM:
        bmCapabilities       0x00
    CDC Union:
        bMasterInterface        0
        bSlaveInterface         1
    Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
        Transfer Type            Interrupt
        Synch Type               None
        Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              32
    bLength                 9
    bDescriptorType         4
    bInterfaceNumber        1
    bAlternateSetting       0
    bNumEndpoints           2
    bInterfaceClass        10 CDC Data
    bInterfaceSubClass      0 Unused
    bInterfaceProtocol      0
    iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            2
        Transfer Type            Bulk
        Synch Type               None
        Usage Type               Data
        wMaxPacketSize     0x0020  1x 32 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
        Transfer Type            Bulk
        Synch Type               None
        Usage Type               Data
        bInterval               0
I’m not 100% sure but could this be wrong path set to find your USB Z-Stick?
Appears to be looking for z-stick at /dev/ttyUSB-ZStick-5G but based on
I think the path should be /dev/ttyACM0
Edit : I see that you mention "/dev/ttyUSB-ZStick-5G points well to /dev/ttyACM0" maybe just try your HA configuration with /dev/ttyACM0.
Indeed, had to reboot and change to /dev/ttyACM0 and it works. Why the symbolic link does not work anymore? They seems ok:
lrwxrwxrwx 1 root root          7 Nov  3  2016 /dev/ttyUSB-RFX433-A -> ttyUSB0
lrwxrwxrwx 1 root root          7 Nov  3  2016 /dev/ttyUSB-ZStick-5G -> ttyACM0
Weird, this was working well previously.
Here are my rules for creating them:
# RFXCOM:
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{serial}=="A1HCLNT", SYMLINK+="ttyUSB-RFX433-A"
# AeoTec Z-Stick Gen5:
SUBSYSTEM=="tty", ATTRS{idVendor}=="0658", ATTRS{idProduct}=="0200", SYMLINK+="ttyUSB-ZStick-5G"
That should work perfectly fine. You seem to be using the method I started last year when I first started using zwave (I can tell because of the unique symlink name I made up :wink: ).
I’ve been using the exact method you are using for over a year and have had no issues.
I don’t think the issues you are experiencing are from a “failed” symlink. From all the info you posted the symlink is obviously working.
From your log above:
if the symlink was not working you wouldn’t see a successful opening of the port based on that symlink address.
But this tells me something might be wrong with the stick:
Try switching back to the “/dev/ttyUSB-ZStick-5G” and see if it works again. Maybe it was a glitch in the z stick itself that caused it.
The problem is if you don’t use a persistent USB path then when you reboot your HA machine the USB address could change and you will be chasing USB addresses for your zwave stick all the time.
Did that, tried several times to switch back and forth, only usb_path: /dev/ttyACM0 works. Weird. I cannot get the fullpath of the symblink to be created /dev/ttyUSB-ZStick-5G => /dev/ttyACM0 instead of => ttyACM0 but I do not see why it should fail…
What command are you running to get this result:
I’ll check mine to see if it matches. So far I can’t see anything obviously wrong.
