NickW
(Nick W)
September 25, 2026, 7:06am
1
Yesterday, I lost my network connection on my NUC / x86-64 Home Assistant OS installation after updating from HAOS 18.2 to 18.3.
Network setup:
Physical Ethernet interface: enp1s0
RTL8111/8168/8411 Ethernet Controller using the r8169 driver
VLAN interface: enp1s0.20
Static IPv4 address on VLAN20
Immediately after upgrading to HAOS 18.3, the Ethernet interface stopped functioning correctly.
After logging in to the CLI, it repeatedly showed:
rtl_rxtx_empty_cond == 0
followed by:
NETDEV WATCHDOG: CPU: 1: transmit queue 0 timed out
Home Assistant OS, Supervisor and the containers themselves continued to boot, but the host had no functional network connectivity. The HA configuration files were still present on de drive.
I switched the HAOS boot slot back to 18.2 using ha os boot-slot other. After rebooting into 18.2, the errors disappeared immediately and the same network configuration and hardware worked normally again.
No router, switch, cabling or VLAN configuration was changed between the 18.3 and 18.2 boots.
This therefore appears reproducible as an HAOS 18.3 or Realtek NIC issue.
jim_os
September 25, 2026, 7:26am
2
NickW:
There are already several issue reports regarding problems with Realtek NICs in HAOS 18.3. Example:
opened 08:24PM - 18 Sep 26 UTC
board/generic-x86-64
stable-kernel-regression
### Describe the issue you are experiencing
Upon upgrading from 18.2 to 18.3, m… y system briefly became visible, but then dropped off the network. I connected directly to the console to diagnose, and found messages about `can't disable ASPM; OS doesn't have ASPM control`, along with repeated `netdev watchdog: cpu: 2: transmit queue 0 timed out rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100)`
It looks like ASPM is repeatedly failing on the rtl8169. I added `pcie_aspm=off pcie_port_pm=off` to the boot command line, with no success. Eventually I had to switch back to 18.2 on boot slot B to recover.
### What operating system image do you use?
generic-x86-64 (Generic UEFI capable x86-64 systems)
### What version of Home Assistant Operating System is installed?
18.3
### Did the problem occur after upgrading the Operating System?
Yes
### Hardware details
KAMRUI Essenx E1 Desktop Mini PC with N150 processor
### Steps to reproduce the issue
1. Update from HAOS 18.2 to 18.3
2. Observe successful DHCP request, brief visibility, then host drops off the network
3.
### Anything in the Supervisor logs that might be useful for us?
```txt
no
### Anything in the Host logs that might be useful for us?
```txt
2026-09-18 18:03:58.176 homeassistant NetworkManager[423]: <info> [1789754638.1759] dhcp4 (enp1s0.100): canceled DHCP transaction
2026-09-18 18:03:58.176 homeassistant NetworkManager[423]: <info> [1789754638.1760] dhcp4 (enp1s0.100): activation: beginning transaction (timeout in 45 seconds)
2026-09-18 18:03:58.176 homeassistant NetworkManager[423]: <info> [1789754638.1760] dhcp4 (enp1s0.100): state changed no lease
2026-09-18 18:03:58.176 homeassistant NetworkManager[423]: <info> [1789754638.1763] device (wlp2s0): state change: disconnected -> unmanaged (reason 'unmanaged-quitting', managed-type: 'full')
2026-09-18 18:03:58.177 homeassistant dbus-broker-launch[118]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
2026-09-18 18:10:50.144 homeassistant NetworkManager[459]: <info> [1789755050.1440] dhcp4 (enp1s0.700): canceled DHCP transaction
2026-09-18 18:10:50.144 homeassistant NetworkManager[459]: <info> [1789755050.1440] dhcp4 (enp1s0.700): activation: beginning transaction (timeout in 45 seconds)
2026-09-18 18:10:50.144 homeassistant NetworkManager[459]: <info> [1789755050.1440] dhcp4 (enp1s0.700): state changed no lease
2026-09-18 18:10:50.144 homeassistant NetworkManager[459]: <info> [1789755050.1442] dhcp4 (enp1s0.100): canceled DHCP transaction
2026-09-18 18:10:50.144 homeassistant NetworkManager[459]: <info> [1789755050.1442] dhcp4 (enp1s0.100): activation: beginning transaction (timeout in 45 seconds)
2026-09-18 18:10:50.144 homeassistant NetworkManager[459]: <info> [1789755050.1442] dhcp4 (enp1s0.100): state changed no lease
2026-09-18 18:10:50.144 homeassistant NetworkManager[459]: <info> [1789755050.1444] device (wlp2s0): state change: disconnected -> unmanaged (reason 'unmanaged-quitting', managed-type: 'full')
2026-09-18 18:10:50.146 homeassistant dbus-broker-launch[118]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
2026-09-18 18:20:57.085 homeassistant NetworkManager[490]: <info> [1789755657.0859] dhcp4 (enp1s0.700): canceled DHCP transaction
2026-09-18 18:20:57.085 homeassistant NetworkManager[490]: <info> [1789755657.0859] dhcp4 (enp1s0.700): activation: beginning transaction (timeout in 45 seconds)
2026-09-18 18:20:57.086 homeassistant NetworkManager[490]: <info> [1789755657.0859] dhcp4 (enp1s0.700): state changed no lease
2026-09-18 18:20:57.086 homeassistant NetworkManager[490]: <info> [1789755657.0861] dhcp4 (enp1s0.100): canceled DHCP transaction
2026-09-18 18:20:57.086 homeassistant NetworkManager[490]: <info> [1789755657.0861] dhcp4 (enp1s0.100): activation: beginning transaction (timeout in 45 seconds)
2026-09-18 18:20:57.086 homeassistant NetworkManager[490]: <info> [1789755657.0861] dhcp4 (enp1s0.100): state changed no lease
2026-09-18 18:20:57.086 homeassistant NetworkManager[490]: <info> [1789755657.0864] device (wlp2s0): state change: disconnected -> unmanaged (reason 'unmanaged-quitting', managed-type: 'full')
2026-09-18 18:20:57.087 homeassistant dbus-broker-launch[118]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
2026-09-18 18:24:46.004 homeassistant NetworkManager[464]: <info> [1789755886.0039] dhcp4 (enp1s0.173): state changed no lease
2026-09-18 18:24:46.004 homeassistant NetworkManager[464]: <info> [1789755886.0042] dhcp4 (enp1s0.700): canceled DHCP transaction
2026-09-18 18:24:46.004 homeassistant NetworkManager[464]: <info> [1789755886.0042] dhcp4 (enp1s0.700): activation: beginning transaction (timeout in 45 seconds)
2026-09-18 18:24:46.004 homeassistant NetworkManager[464]: <info> [1789755886.0042] dhcp4 (enp1s0.700): state changed no lease
2026-09-18 18:24:46.004 homeassistant NetworkManager[464]: <info> [1789755886.0044] dhcp4 (enp1s0.100): canceled DHCP transaction
2026-09-18 18:24:46.004 homeassistant NetworkManager[464]: <info> [1789755886.0044] dhcp4 (enp1s0.100): activation: beginning transaction (timeout in 45 seconds)
2026-09-18 18:24:46.004 homeassistant NetworkManager[464]: <info> [1789755886.0044] dhcp4 (enp1s0.100): state changed no lease
2026-09-18 18:24:46.004 homeassistant NetworkManager[464]: <info> [1789755886.0047] device (wlp2s0): state change: disconnected -> unmanaged (reason 'unmanaged-quitting', managed-type: 'full')
2026-09-18 18:24:46.006 homeassistant dbus-broker-launch[120]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
2026-09-18 18:29:25.952 homeassistant systemd[1]: Stopping WPA supplicant...
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9521] dhcp4 (enp1s0): canceled DHCP transaction
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9521] dhcp4 (enp1s0): activation: beginning transaction (timeout in 45 seconds)
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9521] dhcp4 (enp1s0): state changed no lease
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9522] dhcp6 (enp1s0): canceled DHCP transaction
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9522] dhcp6 (enp1s0): activation: beginning transaction (timeout in 45 seconds)
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9522] dhcp6 (enp1s0): state changed no lease
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9525] dhcp4 (enp1s0.173): canceled DHCP transaction
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9525] dhcp4 (enp1s0.173): activation: beginning transaction (timeout in 45 seconds)
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9525] dhcp4 (enp1s0.173): state changed no lease
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9527] dhcp4 (enp1s0.700): canceled DHCP transaction
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9527] dhcp4 (enp1s0.700): activation: beginning transaction (timeout in 45 seconds)
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9527] dhcp4 (enp1s0.700): state changed no lease
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9529] dhcp4 (enp1s0.100): canceled DHCP transaction
2026-09-18 18:29:25.952 homeassistant NetworkManager[466]: <info> [1789756165.9529] dhcp4 (enp1s0.100): activation: beginning transaction (timeout in 45 seconds)
2026-09-18 18:29:25.953 homeassistant NetworkManager[466]: <info> [1789756165.9529] dhcp4 (enp1s0.100): state changed no lease
2026-09-18 18:29:25.953 homeassistant NetworkManager[466]: <info> [1789756165.9532] device (wlp2s0): state change: disconnected -> unmanaged (reason 'unmanaged-quitting', managed-type: 'full')
2026-09-18 18:29:25.954 homeassistant dbus-broker-launch[118]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
2026-09-18 18:29:25.956 homeassistant wpa_supplicant[477]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
2026-09-18 18:29:25.956 homeassistant wpa_supplicant[477]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
2026-09-18 18:29:25.956 homeassistant wpa_supplicant[477]: wlp2s0: CTRL-EVENT-TERMINATING
2026-09-18 18:29:26.090 homeassistant systemd[1]: Unmounting Docker persistent user...
2026-09-18 18:29:26.090 homeassistant systemd[1]: Unmounting Dropbear persistent user...
2026-09-18 18:29:26.093 homeassistant systemd[1]: Unmounting Temporary Directory /tmp...
2026-09-18 18:29:26.095 homeassistant systemd[1]: Unmounting NetworkManager persistent data...
2026-09-18 18:29:26.097 homeassistant systemd[1]: Unmounting Bluetooth persistent state...
2026-09-18 18:29:26.098 homeassistant kernel: r8169 0000:01:00.0 enp1s0: NETDEV WATCHDOG: CPU: 0: transmit queue 0 timed out 6129 ms
2026-09-18 18:29:26.099 homeassistant systemd[1]: Unmounting Docker persistent data...
2026-09-18 18:29:26.116 homeassistant kernel: audit: type=1131 audit(1789756166.102:492): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-growfs@mnt-data comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
2026-09-18 18:29:26.116 homeassistant kernel: EXT4-fs (zram2): unmounting filesystem 15178063-2416-4a20-9416-f2f71fb6e9a7.
2026-09-18 18:29:26.116 homeassistant kernel: r8169 0000:01:00.0 enp1s0: rtl_rxtx_empty_cond == 0 (loop: 42, delay: 100).
### System information
_No response_
### Additional information
_No response_
