No neutral wire Smart switches
Hi all,
I’d like to ask for recommendation for smart switches that does not require neutral wire. which must include the following:
No cloud connectivity
must be able to control at least 1-3 switch, 4 best
If possible to control dimming
same protocol. (currently on wifi only)
cost is a consideration as well
I found that there is broadlink which uses a rm pro to control the switches via rf capabilities but im unsure if the brand is reliable. I have a rm 4 mini but unsure on how to check if its communicating to the internet after i connected it to home assistant and my logs in my router are quite messy
i recommend going zwave and getting inovelli red dimmers, they will work without neutrals.
Lutron Caseta Pro hub with their switches (you can use the cloud but it also allows direct connection from home assistant via custom component).
I second the lutron caseta recommendation from @monsieurlatte. They work flawlessly with HA and if you need 3 or 4 way switches the costs get much more reasonable when using Pico remotes for secondary+ switches.
+1 for Lutron Caseta with Pro hub.
This is by far my most reliable smart device tupe in my home. I previously had zwave switches but was forced to use Caseta when I moved to my new home without neutral wiring. Blessing in disguise. They aren’t cheap though.
