I have the matter thermostate 7iE from warmup. But in the climate entity, there are no preset_modes and so the set_preset_mode action does not work.
This means that if I programmatically set a temperature, I cannot return to the normal schedule.
Is this a limitation of matter or did the warmup developers forget it?
Also, I found that there is not hvac_mode "auto", only "heat" and "off". So one cannot check if it is running with a fixed temp or on a schedule. But this seems to be a bug in the device.
