I have the Minoston MS11Z dimmer switch. It is supposed to have scene support for 2 scenes. I’m using the OZW, which shows 2 scenes in the user values but they both say inactive and I can’t change it.
I know this post is old but I just spent a bit trying to figure this out on my new Minoston 3 way switch (not a dimmer) and finally figured out its not under the Device settings.
Once you have the device setup you have to create an automation, select Device as the condition and select your device that has a scene. in the Trigger value pick either the Central Scene Action on Endpoint 0 Scene 001 or 002. On my device it only supports two scenes and when I double tapped after creating the automation it did the action I had set in the automation. You can see you could also have it do something on node failure or other settings.
