No Setup Function Defined when setup_platform exists?
Can anyone explain why i would get the error No Setup Function Defined when setup_platform is defined like below?
def setup_platform(hass, config, add_entities, discovery_info=None):
"""Component for interacting with the Yale Smart Alarm System API."""
import logging
import voluptuous as vol
from yalesmartalarmclient.client import (
    AuthenticationError,
    YaleSmartAlarmClient,
from homeassistant.components.binary_sensor import BinarySensorEntity
from homeassistant.const import (
    CONF_NAME,
    CONF_PASSWORD,
    CONF_USERNAME,
import homeassistant.helpers.config_validation as cv
DOMAIN = "yale_smart_alarm.sensor"
CONF_AREA_ID = "area_id"
DEFAULT_NAME = "Yale Smart Alarm"
DEFAULT_AREA_ID = "1"
_LOGGER = logging.getLogger(__name__)
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
        vol.Required(CONF_USERNAME): cv.string,
        vol.Required(CONF_PASSWORD): cv.string,
        vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
        vol.Optional(CONF_AREA_ID, default=DEFAULT_AREA_ID): cv.string,
    """Set up the alarm platform."""
    name = config[CONF_NAME]
    username = config[CONF_USERNAME]
    password = config[CONF_PASSWORD]
    area_id = config[CONF_AREA_ID]
    try:
        client = YaleSmartAlarmClient(username, password, area_id)
    except AuthenticationError:
        _LOGGER.error("Authentication failed. Check credentials")
        return
    for door in client.get_doors_status():
        add_entities([YaleBinarySensor(hass, ctrl, name, sensor)], True)
class YaleBinarySensor(Entity):
    """Implementation of a Yale binary sensor."""
    def __init__(self, device_name, client, yale_object):
        """Initialize the sensor."""
        self.device_name = device_name
        self.client = client
        self.yale_object = yale_object
    @property
    def name(self):
        """Return the name of the sensor."""
        return self.device_name
    @property
    def state(self):
        """Return the state of the sensor."""
        if self.yale_object[self.device_name] == "closed":
            return STATE_ON
        else:
            return STATE_OFF
    @Throttle(MIN_TIME_BETWEEN_UPDATES)
    def update(self):
        """Update sensor data."""
        self.yale_object = self.client.get_doors_status()
I’ve had the same problem and finally realized I was adding it to my configuration.yaml wrong.
I was defining it in configuration.yaml as:
custom_component:
…when it should have been under the “sensor:” block (since it was a sensor component) like:
    - platform: custom_component
