No sign up window - VirtualBox installation on PC
Hello everybody, newie here.
I have been following the steps carefully but I am stuck in this window:
when i should get this one:
the network icon has this red circle flashing continuosly between green and red (I selected bridge and my PC is connected with the router by wifi):
The last line in local 8123 is “INFO (MainThread) [supervisor.resolution.fixup] System autofix complete” which looks good, but it doesn’t go to the sign up windows… any help will be good! thank you
this is the screen i (think i) need to go but i can’t:
the red flashing icon:
Click the blue circle and you’ll get some logs
hello @Tinkerer ! Do you want me to copy the whole log? In the first post I wrote the last line (which I understand that everything went correct): "INFO (MainThread) [supervisor.resolution.fixup] System autofix complete”
I forgot to say that in “http://homeassistant.local:4357/” everything was green and ok.
Thanks for your reply!
i just restart the pc (again) and it worked! did no change, but I am on the registering windows and configuring the profile. thanks anyway!!
