Hello
I’m running Home Assistant 0.85.0 (hass.io 1.13) on a Pi 3B+ on a basic home network. Home Assistant is not discovering my SONOS system, although clearly knows its there! I have discovery turned on and no manual configuration defined for SONOS.
SONOS is reported as ‘Configured’ in Configuration Integrations, but that “This integration has no devices”.
After restart, the developers info tab shows:
No Sonos speakers found
components/media_player/sonos.py (WARNING).
The log includes the following. I’m not sure why spotify_connect is discovered, as I do not use Spotify. I’ve no idea what the dlna_dms / dmr items are either!
2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: spotify_connect {'host': '192.168.1.209', 'port': 1400, 'hostname': 'sonos000E58B007F9.local.', 'properties': {'VERSION': '1.0', 'CPath': '/spotifyzc'}} 2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: spotify_connect {'host': '192.168.1.213', 'port': 1400, 'hostname': 'sonosB8E93788EB66.local.', 'properties': {'VERSION': '1.0', 'CPath': '/spotifyzc'}} 2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: spotify_connect {'host': '192.168.1.205', 'port': 1400, 'hostname': 'sonos000E582008C6.local.', 'properties': {'VERSION': '1.0', 'CPath': '/spotifyzc'}} 2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dms {'host': '192.168.1.205', 'port': 1400, 'ssdp_description': 'http://192.168.1.205:1400/xml/device_description.xml', 'name': '192.168.1.205 - Sonos ZP80', 'model_name': 'Sonos ZP80', 'model_number': 'ZP80', 'serial': None, 'manufacturer': 'Sonos, Inc.', 'udn': 'uuid:RINCON_000E582008C601400', 'upnp_device_type': 'urn:schemas-upnp-org:device:ZonePlayer:1'} 2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dms {'host': '192.168.1.209', 'port': 1400, 'ssdp_description': 'http://192.168.1.209:1400/xml/device_description.xml', 'name': '192.168.1.209 - Sonos Playbar', 'model_name': 'Sonos Playbar', 'model_number': 'S9', 'serial': None, 'manufacturer': 'Sonos, Inc.', 'udn': 'uuid:RINCON_000E58B007F901400', 'upnp_device_type': 'urn:schemas-upnp-org:device:ZonePlayer:1'} 2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dms {'host': '192.168.1.212', 'port': 1400, 'ssdp_description': 'http://192.168.1.212:1400/xml/device_description.xml', 'name': '192.168.1.212 - Sonos Play:1', 'model_name': 'Sonos Play:1', 'model_number': 'S1', 'serial': None, 'manufacturer': 'Sonos, Inc.', 'udn': 'uuid:RINCON_B8E93788EB2E01400', 'upnp_device_type': 'urn:schemas-upnp-org:device:ZonePlayer:1'} 2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dms {'host': '192.168.1.213', 'port': 1400, 'ssdp_description': 'http://192.168.1.213:1400/xml/device_description.xml', 'name': '192.168.1.213 - Sonos Play:1', 'model_name': 'Sonos Play:1', 'model_number': 'S1', 'serial': None, 'manufacturer': 'Sonos, Inc.', 'udn': 'uuid:RINCON_B8E93788EB6601400', 'upnp_device_type': 'urn:schemas-upnp-org:device:ZonePlayer:1'} 2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dmr {'host': '192.168.1.205', 'port': 1400, 'ssdp_description': 'http://192.168.1.205:1400/xml/device_description.xml', 'name': '192.168.1.205 - Sonos ZP80', 'model_name': 'Sonos ZP80', 'model_number': 'ZP80', 'serial': None, 'manufacturer': 'Sonos, Inc.', 'udn': 'uuid:RINCON_000E582008C601400', 'upnp_device_type': 'urn:schemas-upnp-org:device:ZonePlayer:1'} 2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dmr {'host': '192.168.1.209', 'port': 1400, 'ssdp_description': 'http://192.168.1.209:1400/xml/device_description.xml', 'name': '192.168.1.209 - Sonos Playbar', 'model_name': 'Sonos Playbar', 'model_number': 'S9', 'serial': None, 'manufacturer': 'Sonos, Inc.', 'udn': 'uuid:RINCON_000E58B007F901400', 'upnp_device_type': 'urn:schemas-upnp-org:device:ZonePlayer:1'} 2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dmr {'host': '192.168.1.210', 'port': 1400, 'ssdp_description': 'http://192.168.1.210:1400/xml/device_description.xml', 'name': '192.168.1.210 - Sonos Sub', 'model_name': 'Sonos Sub', 'model_number': 'Sub', 'serial': None, 'manufacturer': 'Sonos, Inc.', 'udn': 'uuid:RINCON_000E589800B601400', 'upnp_device_type': 'urn:schemas-upnp-org:device:ZonePlayer:1'} 2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dmr {'host': '192.168.1.212', 'port': 1400, 'ssdp_description': 'http://192.168.1.212:1400/xml/device_description.xml', 'name': '192.168.1.212 - Sonos Play:1', 'model_name': 'Sonos Play:1', 'model_number': 'S1', 'serial': None, 'manufacturer': 'Sonos, Inc.', 'udn': 'uuid:RINCON_B8E93788EB2E01400', 'upnp_device_type': 'urn:schemas-upnp-org:device:ZonePlayer:1'} 2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dmr {'host': '192.168.1.213', 'port': 1400, 'ssdp_description': 'http://192.168.1.213:1400/xml/device_description.xml', 'name': '192.168.1.213 - Sonos Play:1', 'model_name': 'Sonos Play:1', 'model_number': 'S1', 'serial': None, 'manufacturer': 'Sonos, Inc.', 'udn': 'uuid:RINCON_B8E93788EB6601400', 'upnp_device_type': 'urn:schemas-upnp-org:device:ZonePlayer:1'} 2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dmr {'host': '192.168.1.215', 'port': 1400, 'ssdp_description': 'http://192.168.1.215:1400/xml/device_description.xml', 'name': '192.168.1.215 - Sonos Play:1', 'model_name': 'Sonos Play:1', 'model_number': 'S12', 'serial': None, 'manufacturer': 'Sonos, Inc.', 'udn': 'uuid:RINCON_7828CAA4165601400', 'upnp_device_type': 'urn:schemas-upnp-org:device:ZonePlayer:1'} 2019-01-15 03:32:47 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: dlna_dmr {'host': '192.168.1.216', 'port': 1400, 'ssdp_description': 'http://192.168.1.216:1400/xml/device_description.xml', 'name': '192.168.1.216 - Sonos Play:1', 'model_name': 'Sonos Play:1', 'model_number': 'S12', 'serial': None, 'manufacturer': 'Sonos, Inc.', 'udn': 'uuid:RINCON_7828CAA4153401400', 'upnp_device_type': 'urn:schemas-upnp-org:device:ZonePlayer:1'}
I have tried multiple restarts of both Home Assistant and SONOS to no avail.
Any suggestions please? Thanks!
