I have a leakage binary Zigbee sensor plugged with MQTT.
Sadly, I don’t have any long term history for this sensor (less than 2 days). Isn’t the default of purge_keep_days
set to 10 days ? Is there a reason why this binary sensor is flushed like that ?
The device itself is fine, I have months of data for the device battery.
I didn’t do any config on the device, I have the default Z2M integration.
availability:
- topic: zigbee2mqtt/bridge/state
value_template: '{{ value_json.state }}'
device:
hw_version: 0
identifiers:
- zigbee2mqtt_...
manufacturer: SONOFF
model: Zigbee water sensor
model_id: SNZB-05P
sw_version: 1.0.2
via_device: zigbee2mqtt_bridge_...
device_class: moisture
object_id: capteurfuite_water_leak
origin:
support_url: https://www.zigbee2mqtt.io
sw_version: 2.2.1
payload_off: false
payload_on: true
state_topic: zigbee2mqtt/CapteurFuite
unique_id: ..._water_leak_zigbee2mqtt
value_template: '{{ value_json.water_leak }}'
Thanks for your help !
