No tuya integration on Home Assistant 2025-11
I am trying to add Tuya integration on a new Home Assistant 2025-11 system :slight_smile: I have copied the user code from the Tuya Smart app, but I cannot get the integration to work. The integration times out and does not add tuya. Everything works fine in the tuya Smart app. I can add other integrations such as Zigbee. I have also tried port forwarding in my hardware firewall, but nothing helps. Any suggestions? Thanks in advance.
start with looking at logs and ‘current known issues’ on the integration you use. tuya local? which repo exactly?
btw, did i mention logs? ;p
