No USB power over new HA Yellow
Ive just installed HA yellow with a rpi5 module fine. Unfortunately i dont have any power from the USBs (Sonoff device or any device small usb hub etc)
I have the POE version plugged into my 48port POE unifi switch.
THe only time i get any power is if i keep it the usb plugged in and connect the ethernet cable. it blips on the usb device for a split second then shuts off. HA stays running no problem.
Jumper is set back to UART. But Ive tried USB aswell. Any advice would be much appreciated. I’ve tried rebooting it many times with many differences to no avail.
Neither contacting home assistant directly or asking on the forum is getting a response. To think i was supporting them by buying there products and paying for the subscription. Ill probably just move back to my unraid server and setup an external connection via my my unifis vpn setup without needing to support the project anymore. Thanks for everything.
Did you try with a normal power supply ?
No because it needs to be POE
Check if your unify POE is compatible with the yellow
I was stupid. So the support finally got back. I installed the rpi5 image rather than the yellow image in the installer (Duur lol) I Can confirm the usbs have power now. All working as it should be.
