No web interface after update to .67
So I’ve tried to update to vsn .67 (again) and I’m having the same problem. I can’t get to the web interface.
I can access SSH & files through Samba, but can’t access the front end at all.
I have tried a couple of reboots of ha and the Pi, but still nothing.
Any idea how I can get things back up??
Check your logs for errors. Had similar
I’ve done a check within SSH and it came back OK. Is there a specific log that that I should look at?
this is my log:
Error decoding json invalid character '\x1b' looking for beginning of value: 2018-04-16 12:48:19 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=turn_on>
2018-04-16 12:48:19 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=turn_off>
2018-04-16 12:48:30 INFO (MainThread) [homeassistant.setup] Setting up discovery
2018-04-16 12:48:31 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.1 seconds.
2018-04-16 12:48:31 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=discovery>
2018-04-16 12:48:34 INFO (MainThread) [homeassistant.components.notify] Setting up notify.pushbullet
2018-04-16 12:48:37 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=notify, service=pushbullet>
2018-04-16 12:48:37 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 22.5 seconds.
2018-04-16 12:48:37 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=notify>
2018-04-16 12:48:37 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.darksky
2018-04-16 12:48:38 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.dark_sky_precip_probability, old_state=None, new_state=<state sensor.dark_sky_precip_probability=0; attribution=Powered by Dark Sky, unit_of_measurement=%, friendly_name=Chance of Precipitation, icon=mdi:water-percent, hidden=True @ 2018-04-16T12:48:38.871076+01:00>>
2018-04-16 12:48:38 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.dark_sky_summary, old_state=None, new_state=<state sensor.dark_sky_summary=Partly Cloudy; attribution=Powered by Dark Sky, friendly_name=Forecast, entity_picture=/static/images/darksky/weather-partlycloudy.svg, icon=mdi:eye, hidden=True @ 2018-04-16T12:48:38.891950+01:00>>
2018-04-16 12:48:38 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.dark_sky_precip_intensity, old_state=None, new_state=<state sensor.dark_sky_precip_intensity=0; attribution=Powered by Dark Sky, unit_of_measurement=mm/h, friendly_name=Rain Gauge, icon=mdi:weather-rainy, hidden=True @ 2018-04-16T12:48:38.922766+01:00>>
2018-04-16 12:48:38 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.dark_sky_daily_high_temperature, old_state=None, new_state=<state sensor.dark_sky_daily_high_temperature=12.5; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=High, icon=mdi:thermometer @ 2018-04-16T12:48:38.960109+01:00>>
2018-04-16 12:48:38 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.dark_sky_daily_low_temperature, old_state=None, new_state=<state sensor.dark_sky_daily_low_temperature=7.5; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Low, icon=mdi:thermometer @ 2018-04-16T12:48:38.986377+01:00>>
2018-04-16 12:48:39 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.dark_sky_temperature, old_state=None, new_state=<state sensor.dark_sky_temperature=12.5; attribution=Powered by Dark Sky, unit_of_measurement=°C, friendly_name=Current, icon=mdi:thermometer @ 2018-04-16T12:48:39.017712+01:00>>
2018-04-16 12:48:39 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.dark_sky_icon, old_state=None, new_state=<state sensor.dark_sky_icon=partly-cloudy-day; attribution=Powered by Dark Sky, friendly_name=Dark Sky Icon, hidden=True @ 2018-04-16T12:48:39.053763+01:00>>
2018-04-16 12:48:41 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.yr
2018-04-16 12:48:41 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.weather_temperature, old_state=None, new_state=<state sensor.weather_temperature=unknown; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., unit_of_measurement=°C, friendly_name=Weather Temperature @ 2018-04-16T12:48:41.492771+01:00>>
2018-04-16 12:48:41 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.weather_symbol, old_state=None, new_state=<state sensor.weather_symbol=unknown; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., friendly_name=Weather Symbol, entity_picture=https://api.met.no/weatherapi/weathericon/1.1/?symbol=None;content_type=image/png @ 2018-04-16T12:48:41.504368+01:00>>
2018-04-16 12:48:41 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.weather_cloudiness, old_state=None, new_state=<state sensor.weather_cloudiness=unknown; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., unit_of_measurement=%, friendly_name=Weather Cloudiness @ 2018-04-16T12:48:41.512584+01:00>>
2018-04-16 12:48:41 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.weather_precipitation, old_state=None, new_state=<state sensor.weather_precipitation=unknown; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., unit_of_measurement=mm, friendly_name=Weather Precipitation @ 2018-04-16T12:48:41.531788+01:00>>
2018-04-16 12:48:44 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.weather_cloudiness, old_state=<state sensor.weather_cloudiness=unknown; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., unit_of_measurement=%, friendly_name=Weather Cloudiness @ 2018-04-16T12:48:41.512584+01:00>, new_state=<state sensor.weather_cloudiness=100.0; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., unit_of_measurement=%, friendly_name=Weather Cloudiness @ 2018-04-16T12:48:44.051648+01:00>>
2018-04-16 12:48:44 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.weather_symbol, old_state=<state sensor.weather_symbol=unknown; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., friendly_name=Weather Symbol, entity_picture=https://api.met.no/weatherapi/weathericon/1.1/?symbol=None;content_type=image/png @ 2018-04-16T12:48:41.504368+01:00>, new_state=<state sensor.weather_symbol=4; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., friendly_name=Weather Symbol, entity_picture=https://api.met.no/weatherapi/weathericon/1.1/?symbol=4;content_type=image/png @ 2018-04-16T12:48:44.057189+01:00>>
2018-04-16 12:48:44 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.weather_temperature, old_state=<state sensor.weather_temperature=unknown; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., unit_of_measurement=°C, friendly_name=Weather Temperature @ 2018-04-16T12:48:41.492771+01:00>, new_state=<state sensor.weather_temperature=14.9; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., unit_of_measurement=°C, friendly_name=Weather Temperature @ 2018-04-16T12:48:44.073145+01:00>>
2018-04-16 12:48:44 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.weather_precipitation, old_state=<state sensor.weather_precipitation=unknown; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., unit_of_measurement=mm, friendly_name=Weather Precipitation @ 2018-04-16T12:48:41.531788+01:00>, new_state=<state sensor.weather_precipitation=0.0; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., unit_of_measurement=mm, friendly_name=Weather Precipitation @ 2018-04-16T12:48:44.088849+01:00>>
2018-04-16 12:48:44 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 27.5 seconds.
2018-04-16 12:48:44 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sensor>
2018-04-16 12:48:44 INFO (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: service=load_platform.sensor, platform=hue, discovered=bridge_id=192.168.1.18>
2018-04-16 12:48:44 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.hue
2018-04-16 12:48:44 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.hall_motion_sensor, old_state=None, new_state=<state sensor.hall_motion_sensor=off; light_level=15365, battery=100, last_updated=['2018-04-16', '11:01:41'], lux=34.39, dark=True, daylight=False, temperature=20.59, on=True, reachable=True, friendly_name=Hall motion sensor, icon=mdi:run-fast @ 2018-04-16T12:48:44.199740+01:00>>
2018-04-16 12:48:44 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.hue, old_state=<state group.hue=unknown; entity_id=('sensor.hall_motion_sensor', 'sensor.hall_temperature', 'sensor.hall_light_level'), order=13, friendly_name=hue @ 2018-04-16T12:48:18.202165+01:00>, new_state=<state group.hue=off; entity_id=('sensor.hall_motion_sensor', 'sensor.hall_temperature', 'sensor.hall_light_level'), order=13, friendly_name=hue @ 2018-04-16T12:48:44.206693+01:00>>
2018-04-16 12:48:45 INFO (MainThread) [homeassistant.setup] Setting up cloud
2018-04-16 12:48:45 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.0 seconds.
2018-04-16 12:48:45 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=cloud>
2018-04-16 12:48:48 INFO (MainThread) [homeassistant.setup] Setting up tts
2018-04-16 12:48:52 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.config_entries>
2018-04-16 12:48:52 INFO (MainThread) [homeassistant.setup] Setup of domain config took 34.4 seconds.
2018-04-16 12:48:52 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config>
2018-04-16 12:48:55 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.cast
2018-04-16 12:48:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_on>
2018-04-16 12:48:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_off>
2018-04-16 12:48:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=toggle>
2018-04-16 12:48:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_up>
2018-04-16 12:48:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_down>
2018-04-16 12:48:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play_pause>
2018-04-16 12:48:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play>
2018-04-16 12:48:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_pause>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_stop>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_next_track>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_previous_track>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=clear_playlist>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_set>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_mute>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_seek>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=select_source>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=play_media>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=shuffle_set>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 39.2 seconds.
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=media_player>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.kitchen_speaker, old_state=None, new_state=<state media_player.kitchen_speaker=unavailable; friendly_name=Kitchen Speaker, supported_features=21437 @ 2018-04-16T12:48:57.236250+01:00>>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.living_room_speaker, old_state=None, new_state=<state media_player.living_room_speaker=unavailable; friendly_name=Living room speaker, supported_features=21437 @ 2018-04-16T12:48:57.258765+01:00>>
2018-04-16 12:48:57 INFO (SyncWorker_6) [pychromecast] Querying device status
2018-04-16 12:48:57 INFO (SyncWorker_13) [pychromecast] Querying device status
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.living_room_tv, old_state=None, new_state=<state media_player.living_room_tv=unavailable; friendly_name=Living room TV, supported_features=21437 @ 2018-04-16T12:48:57.287032+01:00>>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.home_group, old_state=None, new_state=<state media_player.home_group=unavailable; friendly_name=Home group, supported_features=21437 @ 2018-04-16T12:48:57.356777+01:00>>
2018-04-16 12:48:57 INFO (SyncWorker_5) [pychromecast] Querying device status
2018-04-16 12:48:57 INFO (SyncWorker_3) [pychromecast] Querying device status
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.kitchen_tv, old_state=None, new_state=<state media_player.kitchen_tv=unavailable; friendly_name=Kitchen TV, supported_features=21437 @ 2018-04-16T12:48:57.518514+01:00>>
2018-04-16 12:48:57 INFO (SyncWorker_14) [pychromecast] Querying device status
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.amazonfire, old_state=None, new_state=<state media_player.amazonfire=unavailable; friendly_name=amazonFire, supported_features=21437 @ 2018-04-16T12:48:57.605544+01:00>>
2018-04-16 12:48:57 INFO (SyncWorker_7) [pychromecast] Querying device status
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.living_room_speaker, old_state=<state media_player.living_room_speaker=unavailable; friendly_name=Living room speaker, supported_features=21437 @ 2018-04-16T12:48:57.258765+01:00>, new_state=<state media_player.living_room_speaker=off; friendly_name=Living room speaker, supported_features=21437 @ 2018-04-16T12:48:57.778069+01:00>>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.kitchen_speaker, old_state=<state media_player.kitchen_speaker=unavailable; friendly_name=Kitchen Speaker, supported_features=21437 @ 2018-04-16T12:48:57.236250+01:00>, new_state=<state media_player.kitchen_speaker=off; friendly_name=Kitchen Speaker, supported_features=21437 @ 2018-04-16T12:48:57.875984+01:00>>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.media_players, old_state=<state group.media_players=unknown; entity_id=('media_player.bedroom_apple_tv', 'media_player.living_room_apple_tv', 'media_player.home_group', 'media_player.kitchen_speaker', 'media_player.kitchen_tv', 'media_player.living_room_tv'), order=14, friendly_name=media_players @ 2018-04-16T12:48:18.210596+01:00>, new_state=<state group.media_players=off; entity_id=('media_player.bedroom_apple_tv', 'media_player.living_room_apple_tv', 'media_player.home_group', 'media_player.kitchen_speaker', 'media_player.kitchen_tv', 'media_player.living_room_tv'), order=14, friendly_name=media_players @ 2018-04-16T12:48:57.894345+01:00>>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.home_group, old_state=<state media_player.home_group=unavailable; friendly_name=Home group, supported_features=21437 @ 2018-04-16T12:48:57.356777+01:00>, new_state=<state media_player.home_group=off; friendly_name=Home group, supported_features=21437 @ 2018-04-16T12:48:57.904374+01:00>>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.media_tab, old_state=<state group.media_tab=unknown; entity_id=('group.media_players',), order=2, view=True, friendly_name=media, icon=mdi:headphones, hidden=True @ 2018-04-16T12:48:18.098769+01:00>, new_state=<state group.media_tab=off; entity_id=('group.media_players',), order=2, view=True, friendly_name=media, icon=mdi:headphones, hidden=True @ 2018-04-16T12:48:57.919827+01:00>>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.living_room_tv, old_state=<state media_player.living_room_tv=unavailable; friendly_name=Living room TV, supported_features=21437 @ 2018-04-16T12:48:57.287032+01:00>, new_state=<state media_player.living_room_tv=off; friendly_name=Living room TV, supported_features=21437 @ 2018-04-16T12:48:57.960925+01:00>>
2018-04-16 12:48:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.kitchen_tv, old_state=<state media_player.kitchen_tv=unavailable; friendly_name=Kitchen TV, supported_features=21437 @ 2018-04-16T12:48:57.518514+01:00>, new_state=<state media_player.kitchen_tv=off; friendly_name=Kitchen TV, supported_features=21437 @ 2018-04-16T12:48:57.970080+01:00>>
2018-04-16 12:48:59 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.asuswrt
2018-04-16 12:49:02 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=tts, service=google_say>
2018-04-16 12:49:02 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=tts, service=clear_cache>
2018-04-16 12:49:02 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 14.0 seconds.
2018-04-16 12:49:02 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=tts>
2018-04-16 12:49:04 INFO (SyncWorker_8) [homeassistant.components.device_tracker.asuswrt] Checking Devices
2018-04-16 12:49:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=device_tracker, service=see>
2018-04-16 12:49:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=group, service=set, service_data=object_id=all_devices, name=all devices, entities=['device_tracker.404e3684dc0e', 'device_tracker.claregrsiphone6', 'device_tracker.clareswrkiphone'], visible=False, service_call_id=1968037648-5>
2018-04-16 12:49:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=device_tracker.404e3684dc0e, old_state=None, new_state=<state device_tracker.404e3684dc0e=not_home; source_type=None, friendly_name=Pixel2 @ 2018-04-16T12:49:04.335196+01:00>>
2018-04-16 12:49:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=device_tracker.claregrsiphone6, old_state=None, new_state=<state device_tracker.claregrsiphone6=not_home; source_type=None, friendly_name=ClareGrsiPhone6 @ 2018-04-16T12:49:04.341326+01:00>>
2018-04-16 12:49:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=device_tracker.clareswrkiphone, old_state=None, new_state=<state device_tracker.clareswrkiphone=not_home; source_type=None, friendly_name=ClaresWrkiPhone @ 2018-04-16T12:49:04.347312+01:00>>
2018-04-16 12:49:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_devices, old_state=None, new_state=<state group.all_devices=not_home; entity_id=('device_tracker.404e3684dc0e', 'device_tracker.claregrsiphone6', 'device_tracker.clareswrkiphone'), order=20, auto=True, friendly_name=all devices, hidden=False @ 2018-04-16T12:49:04.361939+01:00>>
2018-04-16 12:49:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.family, old_state=<state group.family=unknown; entity_id=('device_tracker.claregrsiphone6', 'device_tracker.404e3684dc0e'), order=4, friendly_name=Awesome People @ 2018-04-16T12:48:18.122125+01:00>, new_state=<state group.family=not_home; entity_id=('device_tracker.claregrsiphone6', 'device_tracker.404e3684dc0e'), order=4, friendly_name=Awesome People @ 2018-04-16T12:49:04.368074+01:00>>
2018-04-16 12:49:04 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 46.1 seconds.
2018-04-16 12:49:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=device_tracker>
2018-04-16 12:49:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1968037648-5>
2018-04-16 12:49:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=device_tracker.404e3684dc0e, old_state=<state device_tracker.404e3684dc0e=not_home; source_type=None, friendly_name=Pixel2 @ 2018-04-16T12:49:04.335196+01:00>, new_state=<state device_tracker.404e3684dc0e=home; source_type=router, latitude=53.006, longitude=-1.4587, gps_accuracy=0, friendly_name=Pixel2 @ 2018-04-16T12:49:04.844831+01:00>>
2018-04-16 12:49:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.family, old_state=<state group.family=not_home; entity_id=('device_tracker.claregrsiphone6', 'device_tracker.404e3684dc0e'), order=4, friendly_name=Awesome People @ 2018-04-16T12:49:04.368074+01:00>, new_state=<state group.family=home; entity_id=('device_tracker.claregrsiphone6', 'device_tracker.404e3684dc0e'), order=4, friendly_name=Awesome People @ 2018-04-16T12:49:04.857134+01:00>>
2018-04-16 12:49:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_devices, old_state=<state group.all_devices=not_home; entity_id=('device_tracker.404e3684dc0e', 'device_tracker.claregrsiphone6', 'device_tracker.clareswrkiphone'), order=20, auto=True, friendly_name=all devices, hidden=False @ 2018-04-16T12:49:04.361939+01:00>, new_state=<state group.all_devices=home; entity_id=('device_tracker.404e3684dc0e', 'device_tracker.claregrsiphone6', 'device_tracker.clareswrkiphone'), order=20, auto=True, friendly_name=all devices, hidden=False @ 2018-04-16T12:49:04.867061+01:00>>
2018-04-16 12:49:27 ERROR (SyncWorker_7) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-04-16 12:49:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event system_log_event[L]: timestamp=1523879367.825605, level=ERROR, message=Failed to connect, retrying in 5.0s, exception=, source=/usr/lib/python3.6/site-packages/pychromecast/socket_client.py>
That looks pretty normal, have you tried doing a clear of the browser cache?
Yeah it’s definitely not that.
Is there anywhere else I should be looking for clues?
My issue was related to:
2018-04-16 07:09:44 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
Are you using the Bluetooth component @Martin_Granger ?
@JS1 Not as far as I’m aware.
OK, just checking as I had a bug that was related to Bluetooth this morning but you have to install the component so you’d know if you had it!
Are you accessing using HTTPS/SSL ? Once I sat there for ages waiting for HA to come back after a reboot and I was accidentally reloading HTTP when I’d configured HA access via HTTPS … DOH!
Again no - accessing it as I always have.
I have thrown in the towel and re flashed the SD card, so hopefully I’ll get everything back up and running soon from a backup. PITA though!!
Well that didn’t go well!!
I have had to give up and go back to my last working full backup (vsn 65.3).
This is driving me insane!
